Dellortoman
- Tasmania, Australia
Had a simple job to do today - replace a crankshaft outrigger bearing on a mate's Jota. I presume it was making a noise last time he had it running (I haven't been able to start the engine yet for reasons unrelated to the bearing). Anyway, I have a replacement bearing and the pullers necessary to remove the inner and outer bearings, so figured it would be a quick job ? Wrong
Found the inner race was loose on the end of the crankshaft. I could spin it and rattle it about with my fingers, but couldn't pull it off with my fingers because of the peening on the end of the shaft. The bearing puller got it off with no trouble. The old inner race had apparently been spinning on the shaft for long enough to wear it down. I took a bunch of measurements and the diameter is between 19.58 and 19.63 (digital caliper moved a bit when I took the photo). So an average of around 19.60, which is 0.4mm down from the original 20mm.
I'm intending to use some Loctite 660 to fill the gap between the crank end and inner bearing race. The blurb says it's OK for gaps up to 0.5mm. While the crank end is undersize, it's still cylindrical (not worn oval or tapered) so I figured I'd use 3 or 4 narrow strips of 0.2mm brass shim (laid axially along the shaft) to keep the bearing centred and aligned while the Loctite cures. Can anyone foresee a problem with that approach?
PS: Piet might be interested to note that there are spring washers under the bolt heads on the clutch (referring to his post on another thread today). There's no evidence of them touching the webs on the inside of the primary cover so perhaps the aftermarket primary cover gasket is a bit thicker than the original.
