murphus
- Lost in the Midwest
This has me somewhat baffled. Slowly putting the 1984 "Colorado RGS" back to running order. Reinstalling removed bodywork. First pic shows right side of tank where fairing extension secures with two allen head bolts. I didn't notice anything odd taking it apart, but going back together noticed the upper threaded fixing point appeared to be but maybe 3mm deep, with only a few threads showing. Further examination showed an allen head set screw firmly screwed home. WTF?
Second pic shows the inside of the gas tank. Curious as to the tank's internal condition, I removed the sending unit. Previous owner lined the tank, and from what I can see for no reason. Metal is all super clean. Looks to be an epoxy-type liner. It's yellowed, hard, but cracking and starting to separate from the steel. I'm inclined to run it as is, avoiding alcohol-blended fuel. I don't see anyway one could remove it without cutting the underside of the tank out ...
I considered the idea the set screw was inserted to seal a hole in the tank maybe caused by someone using the wrong length fixing screw for the fairing and somehow punching through the tank, with the liner installed to further seal the tank, but there's no indication of any damage at that point.
