Zane 650 clutch
Der LP
Germany
Hallo I have a Zane era 650 built in 1995 and I have some issue with the clutch slipping when the rpm goes over 7,500
that´s why I´m looking for stronger clutch springs and new clutch disks and pads but I cant find anything online
does anyone know where I can finde these parts or from which motorcycles parts would fit that I can look for.
Some owners have reported slipping clutch issues running fully synthetic oil in the 650. I use Morris oils semi synthetic.
Early 650 engines had 7 plate clutches but these were later changed to 9 plate to overcome slipping issues. It is possible to upgrade.
Buying a new set of springs from 3C Moto will probably do the trick. You will find that the latest ones are much shorter (!) and stiffer than your original ones. They will make your clutch a bit heavier though.
I also replaced my plates but I don’t think that was what did the fix. The plates are made by Adige, with part number LV35 for a pack. I’m sure 3C Moto will sell you a set.
