Zane 750 air intake tubing
cooky
Devon
Ok, I know this has been asked before, but has anyone got a pair of 45mm air intake hoses for a Zane 750? Mine are perishing. Tried some metal 45mm hoses but turned out to measure 47mm and would not fit! Cooky
search for FoxiVulca Sil 2. very smooth inside, very stiff, easier to mount. Oh - and it's orange  :D (though not the same orange as Laverda used...)
http://www.foxiflex.com/en/products/hoses-for-high-temperatures/foxivulca-sil-2.html
Something like this, Cooky?
Go:
http://www.ebay.co.uk/itm/45mm-1-75-1m-ID-Heater-Ducting-Hose-Hot-Air-/200586742212#vi-content
Ciao
Craig
Thanks Lothar and Ventodue. It seems that when yo start looking you can find any number of flexible hoses. However, although some state that they are 45mm diameter, the two I have ordered so far have been inaccurate and proved too wide. I will let you know what works when I find it.
Thanks Lothar and Ventodue. It seems that when yo start looking you can find any number of flexible hoses. However, although some state that they are 45mm diameter, the two I have ordered so far have been inaccurate and proved too wide. I will try these new suggestions and hopefully one will fit.
Received the air ducting from apmotorstore. Looks exactly like the picture you posted Ventodue. It also looks remarkably like the OEM tubing.
Saving vast amounts of money and effort finding original laverda tubing. Money saved will probably be spent fixing something else! cooky.
Hi -
I have some of the zane front tubing available if you are still interested.  These are OEM tubes.  Send me your email address and I will send pics if you want.
If you want to get brand new you can order it from airtech, link is http://www.airtech-streamlining.com/miscpages/foam.htm, scroll down the page and you will see the airtubes
Note:  When you speak to them you will want to specify a 1.75 inch tube.
Only problem with airtech is they can take a while to ship.  I placed an order with them that got buried somewhere in their system, took about 4 weeks
martin/dallaslavowner
dallaslavowner@gmail.com
