Chris M. said:
I don't know if this will help you ghwallice. I bought one of Cliff Jefferies ECU's about 15 or so years ago and installed it on a Guzzi I owned at the time. His ECU is basically your old unit gutted and installed with his. It plugged into the Guz electrical system and you then uploaded the map and off you went. The attraction was that you could hook up a data cable from your PC or laptop and plug it into the ecu, extract the map, have a fiddle and then drop it back in. I got my map off a bloke in Tassie, Phil Arnold. I hated the vibration on my V11 and Phil helped me change a number of parts of map to richen up the fuel ratio. The bike still vibrated so I sold it and bought a Laverda but found it had the same problem. He certainly would be able to help you because he's into any engine and love Dry Lakes racing so I'm sure he's easy to find.
To use a MYECU I'm guessing that you need to dovetail the wiring system of this ecu to the Lav electrical system/TPS/sensors etc. I'm sure Cliff J would have a bit of an idea of the wiring requirements because that's what he's into. I recall he didn't have much of an idea when it came to the mapping though that may have changed by now.
From memory map writers use Microsoft NOTEPAD and I think still have it I think if you want a copy. Below is what one of the maps I was given looks like.
# TDC is the pulse count for TDC power stroke of cylinder 1 ( i.e. When the spark fires
# CylOffs is the number of degrees between success cylinders ( 0-720)
# PulsesPer is the number of pulses for the 720 degree 4 stroke cycle
MyECU Cfg TDC=0x1600, CylOffs=270, PulsesPer=48, MissingPulses=3
# CoilCharge is the period in us for charging the coils. 0 for cranking, 1 for running
# Warning, Setting coil charge too high can cook the output transistors and coils
MyECU Cfg CoilCharge0=6000,CoilCharge1=2500
# Pressure - mV and mB values defines a line representing the air pressure conversion
MyECU Cfg Pressure=249mV,121mB,4199mV,1060mB
b
# There are 8 possible voltage targets available 0-7
# The first number for 0 should be 0.0 and means open loop
# For simple sensors where richer is more voltage, all numbers should be positive
# For later sensors where leaner is more voltage, all numbers should be negative
MyECU Cfg O2=0.00V,-2.25V,-2.75V,-2.50V,-2.25V,-2.00V,-1.75V,-1.50V,
MyECU Cfg 2ndO2Sensor=yes
# RPM specifies the maximum RPM.
# TPS specifies the throttle value at idle (no fast idle).
MyECU Cfg RPM=8620, TPS=56
# TDCWhileCranking=1 will fire the spark at TDC
# TDCWhileCranking=0 will fire with advance from the map
MyECU Cfg TDCWhileCranking=1
# This table relates to the injector open/close times as a function of voltage
# The value here is roughly the time ( in us )
# 16V 15V 14V 13V 12V 11V 10V 9V
InjVOn 1000 1000 1100 1200 1500 1700 2000 2500
# TempR gives the value in ohms of the NTC temperature sensor
#Temp C -30 -20 -10 0 10 20 25 30 40 50 60 70 80 90 100 110 125
TempR 51466 28618 16571 9712 5956 3742 2991 2408 1597 1077 746 524 375 274 203 152 102
# Prime gives the fuel injection time in ms while cranking
Prime 30 30 25 20 17 12 11 9 8 7 6 5
# Crank is the %% boost of the map injection times right after start
# this boost decays to 0 over about 20s
Crank 80 70 65 60 60 60 55 50 35 25 20 15 15 15 15 0
# OilT is the permanent choking boost
OilT% +64.1 +53.1 +43.8 +35.2 +29.7 +18.8 +10.2 +9.4 +5.5 +0.0
# AirT is the barometric adjustment for air temp(based on ideal gas law)
AirT% +24.7 +19.8 +15.2 +11.0 +7.1 +3.4 +1.7 +0.0 -3.2 -6.2
# This defines the throttle breakpoints. This on top of TPS base above
THR 960 896 832 704 640 576 512 448 384 320 256 192 128 64 0
RPM 500 1100 1500 1801 2000 2302 2601 2900 3360 3654 4045 4655 5353 6157 7082 8143
SpkAdv 14 11.02 12.42 13.36 19.45 22.03 23.44 25.31 27.19 27.42 32.81 34.45 36.56 36.56 36.56 35.16 35.16
SpkAdv 13 11.02 12.42 13.36 19.45 22.50 23.67 25.55 27.42 27.89 29.06 34.45 36.56 36.56 36.56 35.16 35.16
SpkAdv 12 11.02 12.42 13.36 19.45 23.44 24.38 25.78 27.66 29.06 29.06 34.45 36.56 36.56 36.56 35.16 35.16
SpkAdv 11 11.02 12.42 13.36 19.45 23.44 24.61 26.25 28.13 30.00 30.47 34.45 36.56 36.56 36.56 35.16 35.16
SpkAdv 10 11.02 12.42 13.36 19.45 23.44 24.38 26.48 28.59 30.47 30.70 34.45 36.56 36.56 36.56 36.56 35.16
SpkAdv 09 11.02 12.42 13.36 19.45 23.44 25.31 27.42 29.06 31.64 32.81 34.45 36.56 37.27 37.50 37.50 37.50
SpkAdv 08 11.02 12.42 13.36 19.45 23.44 25.31 27.42 29.06 32.58 34.45 35.86 37.73 39.61 39.84 39.84 39.84
SpkAdv 07 11.02 11.02 13.36 19.45 23.44 25.31 28.83 29.06 32.81 34.69 36.33 39.14 40.31 41.02 41.02 41.02
SpkAdv 06 11.02 9.84 13.36 19.45 23.44 25.31 28.83 31.64 33.28 35.86 38.91 40.78 41.72 42.66 42.66 42.66
SpkAdv 05 11.02 9.61 13.36 19.45 23.44 25.31 28.83 31.64 34.22 37.73 40.78 42.42 43.59 44.06 44.06 44.06
SpkAdv 04 11.02 9.38 13.36 19.45 23.44 25.31 28.83 31.64 34.22 37.73 40.78 42.42 43.59 44.06 44.06 44.06
SpkAdv 03 11.02 9.38 13.13 19.45 24.14 25.31 28.83 31.64 34.22 37.73 40.78 42.42 43.59 44.06 44.06 44.06
SpkAdv 02 11.02 9.38 13.13 19.45 24.14 26.95 29.30 31.64 34.22 37.73 40.78 42.42 43.59 44.06 44.06 44.06
SpkAdv 01 13.13 9.38 13.13 19.45 25.08 29.30 29.77 31.64 34.22 37.73 40.78 42.42 43.59 44.06 44.06 44.06
SpkAdv 00 13.13 8.20 4.92 14.30 25.08 29.30 29.77 31.64 34.22 37.73 40.78 42.42 43.59 44.06 44.06 44.06
InjAdv 14 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600
InjAdv 13 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600
InjAdv 12 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600
InjAdv 11 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600
InjAdv 10 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600
InjAdv 09 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600
InjAdv 08 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600
InjAdv 07 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600
InjAdv 06 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600
InjAdv 05 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600
InjAdv 04 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600
InjAdv 03 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600
InjAdv 02 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600
InjAdv 01 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600
InjAdv 00 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600
InjDur 14 3984 11408 11296 11008 10848 10672 10464 10288 10400 10368 10064 9920 10656 12016 11712 11376
InjDur 13 3984 11360 11248 10960 10800 10640 10416 10224 10320 10304 10032 9856 10496 11696 11392 11136
InjDur 12 3984 11280 11136 10848 10688 10544 10320 10096 10144 10128 9936 9712 10128 10944 10640 10608
InjDur 11 3984 10960 10816 10624 10512 10304 10048 9824 9696 9552 9200 8544 8624 8960 8592 8480
InjDur 10 3984 10736 10592 10512 10464 10144 9888 9664 9424 9120 8528 7952 8112 8256 7280 6864
InjDur 09 3984 9360 9248 9120 9056 8816 8592 8384 8272 8096 7680 5616 5984 6256 5888 5520
InjDur 08 3984 7968 7872 7712 7632 7456 7280 7104 6768 6416 5856 5312 4960 4784 4736 4160
InjDur 07 3984 7888 7616 7488 7424 7200 7024 6896 6512 6048 5248 4576 4576 4496 4432 4016
InjDur 06 3984 7840 7200 7056 6976 6400 6112 5920 5728 5136 4976 4576 4048 3920 3616 3872
InjDur 05 5184 7072 6608 6240 6032 5168 5344 5104 4912 4640 4176 4016 3520 3632 3184 2848
InjDur 04 4880 5168 5440 4976 4816 3872 4160 4240 3968 3808 3616 3152 2896 3040 2912 2480
InjDur 03 4688 4016 4128 4128 4128 3488 3312 3536 3232 3056 2864 2832 2464 2208 2112 2080
InjDur 02 4640 4960 4896 3328 3312 2944 2800 2752 2752 2544 2352 1936 1600 1504 1504 1504
InjDur 01 4544 4464 4304 2464 2368 2256 1984 1856 1728 1424 1408 1184 1040 1040 912 752
InjDur 00 4032 3984 3520 1776 1440 1536 1216 1216 1136 1040 1040 992 992 992 752 608
CylOfs 14 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 13 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 12 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 11 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 10 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 09 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 08 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 07 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 06 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 05 +0 +0 +0 +0 +0 +0 -1 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 04 +0 +0 +0 +0 +0 +0 -1 +0 -1 +0 +1 +0 +0 +0 +0 +0
CylOfs 03 +0 +0 +0 +0 +0 +2 +0 +4 +2 +1 +0 +0 +0 +0 +0 +0
CylOfs 02 +0 +0 +0 -1 +0 +1 -5 +4 -2 +1 +3 +0 +0 +0 +0 +0
CylOfs 01 +0 +0 +0 +0 -2 -4 -4 -3 +2 -1 +1 +0 +0 +0 +0 +0
CylOfs 00 +0 +5 -2 -3 -4 -2 +0 -2 +0 +1 +0 +0 +0 +0 +0 +0
Flags 14 (O0) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1)
Flags 13 (O0) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1)
Flags 12 (O0) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1)
Flags 11 (O0) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1)
Flags 10 (O0) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1)
Flags 09 (O0) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1)
Flags 08 (O0) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1)
Flags 07 (O0) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1)
Flags 06 (O0) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1)
Flags 05 (O0) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1)
Flags 04 (O0) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1)
Flags 03 (O0) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1)
Flags 02 (O0) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1)
Flags 01 (O0) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1)
Flags 00 (O0) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1)
