Ventodue said:Be VERY careful about how much you put into that 'header tank'. Because 'header tank,' it is NOT.
It's an expansion vessel. You put too much fluid in it to start with, when the radiator gets hot, the expanding coolant will start to fill that tank and, it being under pressure, the tank will split along the seams. Many people have made this mistake.
Do NOT fill the tank, when cold, above the minimum mark!
thanks for the precious advice.
I serviced my cooling system last year, because of a lack of liquid from the water pump sealings.
For sure I refilled too muck the "nourrice" (why the f they called it this way?) and it started bleeding, when in pressure.
checking it, I noticed some filler in the crack: someone made the same mistake before me!
I ordered a brand new one, and now it's of course ok.
BTW, I still have some drops from the hole under the water pump shaft. I'm afraid I have some scratch on the shaft sealig housing. I have to reassemble it with some liquid sealing to fill it.
