Schurminater
- Surrey Hills
Next Question if I may re Triples,
I have already read and learnt a lot from this forum regarding the Cam block issues and the fitting of them,but are there different types and are they interchangeable between cams...?
From what i can tell there are two part numbers for the outer blocks but various heights of offset, and it looks from the parts drawing that they can fit in dual positions ie inlet left or Exhaust right........is that correct?..........so if that is the case they are not machined matched to the head and could well be refitted in a different position if you didn't take care when dismantling.
And finally do or did any of them have shell/bearing inserts or are they all just plain Alloy?
Appreciate some education on the subject please,
thanks in advance. (thumbup)
Schurmie
Schurmie
