3C back from the dead
By the way Red, one of your very early alternator and ignition conversions is on my bike, first time it's been used in anger since, what 2011?
The upgrade unit on my 3C was also one of Red's first batch.
Seem to recall that it was a year or two before 2011, the date of my saved/copied install notes file is 2010.
Used in anger since then, and still going strong, the generated current even melts fuses!
Best 180 upgrade ever.
It's been very cold here so I haven't been out on the bike but I've had it running quite a bit, sounds nice but it's a bit iffy at tickover so I'll have to adjust that.
Sorted my rev counter cable out, a new spring for the rear brake light, fitted a new indicator lens when one fell to pieces as I unscrewed it but the right indicators won't flash.
I've swopped the bulbs around, sorted earths out, checked the wiring is correct in the headlamp but still no dice.
The only thing left is the switch so I'll take a look at that this weekend. I did notice when I was doing the earths that there was a faint glow from the front left indicator when the right one was switched on but it disappeared when I earthed the right one properly. Maybe the wires are damaged in the switch?
I need to polish the alloy as well but that will come later. Those pipes sound great by the way.
I was guessing at 2011 Tom but it is around that date somewhere I think.
And my Nonna is 1445
I won't make any comments about DPOs and parts wear, CK! :eek:
If we look at the know statistics regarding known 3Cs there were approx 2500 bikes built there is just over 10% known to still be owned.
As far as the drummer component of the 3Cs go approx 250 bikes mde and there is about 10% known to still exist.
Even if we double the number and come up with 20% which is quite possible there vwould only be about 500 bikes still in existence.
Not bad really considering we are talking about a potentially unreliable bike from the early 1970s nearing 47 years old.
That would be a very good statistic I would say. Compared to other bike brands and models it is a very high percentage. The reason would be that these bikes grow on you in such a good way.
And the dedication of engineers and suppliers without whom owners would struggle to keep their bikes running.
I won't make an incomplete list, but most of you will know who I mean.
