I don't feet unsafe on the road as result of out 'lax' regs, and that's the main thing.
It's not unroadworthy vehicles that cause problems on our roads, it's unroadworthy drivers.
I see drivers doing something stupid pretty much every time I go out on the road. The most common idiot behaviour that I see is texting while driving. The other (and probably more common) idiot behaviour is drug or alcohol affected driving, but that's not as easy to see by simple observation.
I did some minor jobs in prep for Sundays NSW club ride. I backed off the Emulator spring preload 1/2 a turn to soften the hits I get from square edged sharp bumps. After years of use the knurled gear lever has started to errode my boot top so I added some shrink wrap, we will see how that lasts and works. And I checked how the latest Regulator was going, still need to keep the headlight on so it stays under 15 volts, there is a fix but I need the brains trust to fit it, my attempt had the starter relay fuse blow immediately. There is a hint as to the FIX, almost plug and play if you wire and plug the ORIGINAL Shendenco in correctly.
Bit of Jota love today, it has been neglected for a while...
Fitted new rubber,Thanks Marty, new rear shocks that had been sitting in the corner for over 6 months and changed out the leaking neutral switch, courtesy of Shaun.
Took it for a quick spin and have to say, those shocks are beautiful, such a change to the Marzocchis, and the neutral switch doesn't leak any more. Result.
They dont want mc inspections here, as roadworthiness is negligible in statistics for accidents. EOS is forcing their introduction, hopefully exempt for old shitheaps.
I have looked in every corner of my place and haven't found any Ohlin shocks, but I am hopeful. Shame the set on my old Husky won't fit, bit long at 16 inches.
  • Like
Reactions: T.C
I cut down the bodies and shafts from Ohlins off a big KTM mx bike for my SF. Easy for any lathe operator. When I was buying seals the Ohlins tech tried to get me to trade them in to him for use in vintage mx.
Mine are not Piggybacks, these reservoir is attached via hoses, kind of a pain to mount. They work SO WELL. Cost a flippen fortune to rebuild, and I had to send to Sweden for the correct short springs in the stack for my weight as Steve Cramer the Oz importer didn't have them in stock. They just soak up every tiny and huge bump like butter.
"Testers are not to assume a vehicle will be parked for 11 months of the year. They have to assume the vehicle will be used as intended, anything borderline should be considered bad enough for a fail.
It's not their neck they're risking, it's yours! Most inspectors take their responsibilities seriously, thankfully.
Although I consider myself able enough to determine if a certain component requires replacement or not, I do appreciate the pointers that inspectors offer when inspecting my vehicles"
Agree entirely Piet, but here in the UK, if the vehicle is fit for use at the time of the test, it doesn't fail, what happens now (changed in the last ten years) is there is a warning on the MOT cert which is listed as "advisory notes", f.e. if your car has four tyres and three of them are above 1.5mm by a big margin and one is measuring 1.6mm (UK min is 1.50mm for cars and 1.00mm for bikes, "visible tread" for under 50cc) the car/bike passes but you have an "advisory", same goes for ball joints that are sound, but perceptable wear is evident, so small that you could not even measure it, .as was my case back in 1970, the idiot tester didnt notice that the car was rotten enough for the doors to pinch, I only owned it for two months and hated it anyway, was getting shot, not that this formulates an excuse.
recently my son had his Transit Trend MOT tested and it passed with flying colours, however, the rear nearside wheel bearing was howling and clearly needed replacement, this doesnt show up during the MOT, since the van is not driven on the highway, but tested on a rolling road, brakes steering wheel bearings etc, there is no play perceptible, so it passed, the bearings where changed two days later.The tester knew nothing of it
Yeah I know Quentin, but Ive been busy on other things...
I did have to make up spacers and so forth as the Ohlins eye ends came to fit 10mm bolts so that slowed me down a bit...
Not too worry I got there in the end.
I made alloy reducer sleeves to take my shock bolts from 12mm down to 10mm anyway, Tom - a good way to reduce unsprung weight and they don't really need those massive bridge rivets anyway! I hope my Nitrons are at least as good as the Ohlins. I've got a fair amount of forward lean, so should be nice and compliant!
speaking of 81 jotas,this arrived from eldorado today,bout a month turnaround,tad expensive ,but the quality:)
Your lucky with a month Paul, my 1200 seat unit has been 5 weeks already and no sign as yet.
Would have used Tony but its a custom and hes too far away.
for replica seats I dont think theres anyone better. (y)
Fitted a new ignition swith to the SF, the old one had been grumbling for a short while, but gave up completely. A side benefit is that the DMC is now a lot happier with a regular voltage supply, the bike fels like it had a thorough tune up :-)
Did a rego on a scooter today, the main bolt that holds the engine to the frame was half out, nut gone, rear shocks holding the whole show together. Totally amazing! Talk about a hinge in the frame! The L plate on the back gave the game away, the young girl had no idea there was any problem.......
  • Wow
Reactions: T.C
