CLEMTOG
took TOG down to the huntsmen pub for out local monthly meet, was testing a repaired hydraulic slave cylinder/sprocket cover, this started out as a horrible item having been welded twice (yuk chicken crap, still leaking) and also sufferred a broken top due to a busted chain, brought back from the dead and as an experiment for my own use, no bleed nipple and the hose straight onto the back of the cylinder, + zero possibility of fluid where you dont want it.
ps next one I might weld up the hole for the rubber bung (done that before on cable types with the long lever) and also the hole in the top where the hose was previously
