hooksey
- Vic , Australia
Nah mate, we got a fella down in Warragul, let me know if you need his services..... top notch fellaLast of the big spenders Davey,they do look goodWas it done byHPC?
Tom
Tom
You wouldn’t dare hide that finish.... or such blasphomy could even cost you a trip to the gallows......They'll look great once you've wrapped them as well....
Are you tarting it up to sell?Treated the ole girl with fresh ceramic coated pipes.....![]()
Down boy...... she’s by no means a tart. More of a mole!Are you tarting it up to sell?
Sorry, but I gotta say it: I love your expression there, Paul ...600km on the 750 S over the weekend. Engine freeing up nicely.
One of Laverda's finest by far.
If the starter freewheel has play on the crank, you needn't worry about the timing.Today I quickly checked Paul's favorite object of desire on the Eagle - the breaker contacts.
It's that straightforward with a simple feeler gauge and a test lamp.
Checking the ignition timing is not optimal as standard. A wire bracket as a pointer is unstable, read off to the marking on the motor housing is imprecise. So that you can check the markings for the ignition timing more precisely on the starter freewheel, I built a simple auxiliary tool that fits all old 750s.
If the starter freewheel is fixed correctly and free of play on the crankshaft, this tool can be used to read the exact TDC.
With every engine, the tool is aligned exactly in the middle of the lateral (pic 2), central cast web on the cylinder.
I tested this on different engines with the dial gauge - the result is accurate.
By the way: Maybe this is due to the oil that I occasionally put on the lubricating felt for the breaker cam - the breaker distance has to be readjusted extremely rarely. The toothed V-belt runs much easier and is very durable - this may be an advantage for our racing drivers.
Thomas aus LAU
View attachment 59477 View attachment 59478 View attachment 59479 View attachment 59480
If the keyway of the starter freewheel on the crankshaft is not OK, the TDC marking is no longer correct. Due to the radius, 0.2 mm clearance/damage have a dramatic effect on the outside of the shaft = several degrees.If the starter freewheel has play on the crank, you needn't worry about the timing.
Why would racers need a dynamo belt?
TDC marking needs checking any how. Slop in the freewheel keyway if that's what you meant ,means crank overhaul, not TDC checking.If the keyway of the starter freewheel on the crankshaft is not OK, the TDC marking is no longer correct. Due to the radius, 0.2 mm clearance/damage have a dramatic effect on the outside of the shaft = several degrees.
The large moving starter pinion on the crankshaft has of course nothing to do with the ignition timing.
With us, the vehicles for the racetrack are also driven on the road (with 07 license plates) - even long distances. This doesn't work for long without a V-belt and only with battery voltage. E.g. all three race bikes from "Pilot" are even driven hard on normal roads.
Thomas aus LAU
I've also often seen keyway´s that are bent or too small....... ,means crank overhaul, ......
Good as a tune upWell I have no pictures but yesterday took my '79 Jota out for a blast did one of my favorite roads Skenes Creek Forest to the GOR bloody wet and quite mossy unfortunately one of my mates on his Hardly Davids bum lost it and ploughed up some mud, then later one of my other mates on his modern Enfield couldn't get the engine to start, the fault was a blown neutral light globe, so if the neutral light will not illuminate there is no starter motor (what a shit system), bit of a shame as the engine and gearbox on those bikes seem to be quite well made!!
So I took off on my second lap solo again with the taps well and truely open on my 42 year old Jota to empty a second tank of fuel.
Man wasn't that good for the soul!!!!!!
Strewth! Had me worried for a moment, first thought you had written 'Blue Oyster Bar'.7 Laverdas made it in glorious sunshine at the last of this years Blue Anchor Bay.
Replacement brushes are available from auto electric suppliers, otherwise easy enough to cut to size.While my sprag is in pieces waiting for parts, I gave the starter motor a once over. Cleaned out the carbon, polished the comm, yada yada. Reassembled and bolted it back on for a test. Nothing... hmmm what did I do wrong? Ahh, the battery has given up the ghost. 3.5 years out of a standard Yuasa, not bad I suppose.
Incidentally, the brushes aren't great, are replacements available? Otherwise I'll get some made up.
It feels like it sometimes!Strewth! Had me worried for a moment, first thought you had written 'Blue Oyster Bar'.
