Oil leak alternator side
russo011
Austria
Anybody had oil leaks from the alternator side?
Finally got my 76 3CL registered, knew the oil leak was there so i replaced the oil seal behind the alternator after about 20 kms up the road it started to leak again.
Will check again of course just wanted to know if this is a common problem? Or is there something else I should be looking for?
This time round I will remove the stator wiring completely to change the gasket on the inner cover itself - was hesitant to do it before as I didn't want to touch the wiring seems I have no choice now though.
Russ,
The oil leak is not common, once you've pulled the alternator and the cover behind you will find that it pays off to service the sprag clutch with new parts.
Gerald
Russ,
Gerald
Thanks Gerald, you mean the 6 springs and pins? Though about renewing the M27 nut as well - the surface has some marks on it, I don't think serious, however, thought I may as well
Hi Russ,
Yes springs, pins, the whole kit. Surface marks on the M27 nut is common from whatever tool was used in the past to undo/fasten.
If the thread is still OK I wouldn't bother.
I have it from an impeccable authority that warping problems are becoming more common, particularly just below the area where the cables go through the cover.
A couple of light passes should level the sealing surface.
thanks - i will check when i get the cover off - hoping that a new gasket will resolve the issue
That's a classic Rob, been there. It's easy to spill some oil doing a change and have it collect under the starter and slowly dribble out of that weep hole.
Check the case on a piece of plate glass with a feeler gauge. I've heard of as much as 10 thou distortion which, sadly, a gasket won't fix.
Checked and maximum gap; it is around 7 to 8 thou (0,18 to 0,19 mm) at the spot by the opening near the wiring opening, I feel that the gasket was the real issue, very hard and cracked in a couple of places.Alternator-cover_01.jpgAlternator-cover_02.jpgAlternator-cover_03.jpg
