Anybody had oil leaks from the alternator side?
Finally got my 76 3CL registered, knew the oil leak was there so i replaced the oil seal behind the alternator after about 20 kms up the road it started to leak again.
Will check again of course just wanted to know if this is a common problem? Or is there something else I should be looking for?
This time round I will remove the stator wiring completely to change the gasket on the inner cover itself - was hesitant to do it before as I didn't want to touch the wiring seems I have no choice now though.
