Evening all.
Having decided to check my valve clearances, I set about removing the cam cover from my Jota. "Looks a piece of cake" I thought.
However, jiggle it as I will, it doesn't want to come off. I searched on here and found an old thread from 14 years ago with a similar issue. It says, turn the crank over a little either way and the cover will release from the tacho drive. What isn't clear (for me anyway!) is - does the tacho drive pull through cover (I've removed the circlip to allow this), or should I leave the circlip in place and remove the cover, complete with the drive attached to it? Is there anything else preventing releasing?
The carbs are still fitted and it also appears the part of the cover is very close to the carb linking bracket. I'm hoping once lifted, it will come clear of the bracket and come off.
Any help gratefully received, thanks.
