Might still be a bit rich. Only way to be sure is to put it on a dyno.
When I got my Jota it was way over-jetted. I think it had 140s or maybe 145s in it. Memory is a bit hazy on the exact number, but apparently the previous owner must have thought bigger jets would make it go better. After a few dyno pulls we came down to 120 mains and it was still a wee bit on the rich side. Factory jetting was 118 but we didn't have any of those available and 115 was too lean. Since then I've swapped to Mikunis. Doesn't go any better but isn't as thirsty.
Funny thing - when the dyno bloke saw how rich it was on the first run with the 140+ mains, he said it may as well not have main jets at all. So just for fun we gave it a run without any mains and he was dead right. It ran the same mixture at WOT as it did with the 140. The needle valve was doing all the fuel metering. It didn't start to lean out until we got down to about 130.
There's a lesson there. If you have 32mm Dellortos with (Laverda factory original) AB265 needle jet + K1 needle, don't bother going any bigger than 130 mains. If you think it needs bigger mains, save your money and run it without main jets.
