Andy
- Auckland, roughly
Good find
How easy is it to find replacements? Is it worth keeping it for rewinding?
I assume you meen BT 016, right? Haven't heard of a BT 106 yet...Put a pair of Bridgestone BT106’s on the Jota,also treated it to anew rear sprocket. Cleaned everything up and bolted it all back together.Should be good to go for the run to Queensland at the end of the month
Tom
Definitely the way to go - no point buying another cos it will break too.Wiring wiring wiring. Only came to a halt when I went to mount the instruments and the mounting spectacles broke, straight across the middle of the centre mounting hole. Checked availability, min of AUD$150 delivered from the usual suspects in Urup. Figuredthat at worst this is what it was going to cost so fired up the old arc welder, clamped on a suitable washer and welded the bastards together. Lined up well, ground off the xs weld and painted it black. You won't see the crappy weld under the mount anyway. Getting closer...
Back in the '70s, everyone I knew of's broke across that joint, mine within a year.Wiring wiring wiring. Only came to a halt when I went to mount the instruments and the mounting spectacles broke, straight across the middle of the centre mounting hole. Checked availability, min of AUD$150 delivered from the usual suspects in Urup. Figuredthat at worst this is what it was going to cost so fired up the old arc welder, clamped on a suitable washer and welded the bastards together. Lined up well, ground off the xs weld and painted it black. You won't see the crappy weld under the mount anyway. Getting closer...
What sizes Tom?Put a pair of Bridgestone BT106’s on the Jota,also treated it to anew rear sprocket. Cleaned everything up and bolted it all back together.Should be good to go for the run to Queensland at the end of the month
Tom
