Laverdalothar
- Germany
Hi Andy, the Corsa's I have seen selling (and they rarely do) were between 8.500 and 11.000 while the 1000 SFC over here sold at that time beyond 10.000 up to partly 13.000 already.
You know well that the 1000 SFC and Corsa engine are the same, right? So - what happened on the 1000 SFC could have happened on the Corsa, too. Absolutely no difference... If you will, the 1000 SFC has the Corsa engine. Difference to the standard RGS engine are just the big bore head and slightly higher compression - that's it. Both even have the standard F1 cam that was also installed on the standard RGS (P1 only for racing/as an upgrade).
When 1000 SFC production started, Corsas and other RGx models were rarely assembled though as they did not sell anymore; maybe because Uwe made so much fuzz around the 1000 SFC that no one tried to sell something else - who knows. But WHEN they were assembled, the Corsas had the same engines as the 1000 SFC, same carbs, same jettings, same exhaust (well - chrome against black paint, but else...). The differences were the externals, like the bodywork and footrests, rims, brake discs and suspension as well as the different instruments (OK - color of the frame, too...). Else they were technically quite the same.
