Dellortoman
- Tasmania, Australia
PHF36 Carbs aren't from a triple. They all came with PHF32 from the factory.
OK, But my throttle slide 60/2 is wrong according to Laverda Paradise catalog and should bee 50/3. Do You think the differens matter ?PHF36 Carbs aren't from a triple. They all came with PHF32 from the factory.
YesOK, But my throttle slide 60/2 is wrong according to Laverda Paradise catalog and should bee 50/3. Do You think the differens matter ?
Those pilot jets are huge. I run 45 (pretty sure I have already told you that), many people prefer slightly richer 50. How many turns out is your mixture screw? With those pilot jets it is likely to be way rich under normal riding and cause it to stutter as if the choke is partially on (and you have checked that the choke plungers are properly seated and their rubber insert seats are in good shape?). If you fit 50 slides with those 60 pilot jets it will be even richer. The needle will be a K2, and the needle jet a 265 unless someone has mucked around with it. The slide cutaway actually has it's major effect in picking up from closed throttle, but as Vince says they affect slightly more open as well. I had 70 slides fitted once as they were all I could get. The bike could idle perfectly but to get it to pick up from idle I had to richen up the idle mixture heaps. You should be able to get it to run properly with those huge pilot jets and 60 slides though. For myself I would fit 50 slides and 45 or 50 pilot jets. It should then idle fine with the usual 1 1/2 to 2 turns out mixture screws unless there is some other problem. Almost all riding is with very small throttle openings so this is the area that is most noticeable. How are you synchronising the carbs?Back in startup again and still problems with low RPM
The carburetors, a PFH36AD is equipped with
pilotjet = 60
mainjet = 145
Needle =?
Throttle slide = 60/2
which indicates that the carburetors come from a triple machine.
750SF is supposed to have a 50/3 throttle slide?
Could this be the cause of the low speed problems and will the replacement of the throttle slide solve the problem.
Valve clearance, cam chain and ignition are checked and are still OK
My first goal is to make it tickoverusing drills to get a "base starting point" is good, but oinly for a starting point, sychronising with a quality instrument (s) will give you a very satisfying result, 750 twins have a habit of showing when synchronising is needed, by ticking over at red lights for instance, for maybe two minutes then dying, choke is needed to get going again, and THAT IS clear signage that your carbs are out, they should tockover indefinately. Be warned though that on ticklover oil circulation is marginal, so even though this proves good carb set up, if you were get stuck for more than a few minutes, kill the motor.
I don't know what's up with your bike.My first goal is to make it tickover![]()
I agriee Paul. The synchro is not the problem. Must bee something else that causes my problemI don't know what's up with your bike.
Synchro will not affect idle unless it's wildly out. And it should more or less run on one cylinder anyway.
My SF2 runs fine on standard carb settings, 55 pilots, 140 mains, K2 needles, 50 slides. If anything, it's a bit rich.
As for synchro, I just stick a finger in the carb intake and make sure that they top out at the same time. Probably not a good technique but it's been going 30 years.
What needles have you got in there?I agriee Paul. The synchro is not the problem. Must bee something else that causes my problem
How do I recon right needles. and if I got the wrong ones should they affect tickover ? 2000rpm and up seems OKWhat needles have you got in there?
Have you got the right mixture screws, there are 2 different lengths?
Have you got the right slides, or modified a new set to correspond with the old carbs if that's what you've got? ( Though new model slides in old carb bodies will probably send the revs way up)
Wrong needles will affect low down running. Needles should be marked K2, and the clip in the middle notch. It needs good eyes to see the marking and of course dismantling the needle.How do I recon right needles. and if I got the wrong ones should they affect tickover ? 2000rpm and up seems OK
Mixture screws block the passages when fully screwed in so I suppose they are the right length.
Slides 60/2 seems old butt not worn or modified
From new ex factory?plenty of triples have had 36mm PHFcarbs fitted,
