Port position is slightly different and stud centres are closer. The actual sealing surface to the inlet stub is the same, the carb angle is given by the stubs.Aren't small valve head inlet angles different as well (so the carbs sit closer to parallel to the ground)? My SF1 had 34.5 at the head but opened back out as it went deeper - apparently a 'double venturi design 36 carb tapering to 34.5 in the inlet stub then back out to 36 beyond. I ported mine to 36mm straight through which I think is std SFC practice.
The exhaust port on the small valve head I used as the basis for the SFQ had a deeper recess for the stepped headers - I had to machine and press in a 'ring' to allow use of std SF1/2/3/C headers. No idea what model the small valve head came off - bought it from Wolfgang.
