Referring to Zane 750S, but I think very similar to the earlier 500. They seems to have quite a lot of backlash at the sprocket, about 30 degrees. I rebuilt a motor (crankshaft) and after about 1000klm I started to get quite a bad gearbox noise above about 80klm/hr. I don’t remember this bike ever doing this, and I came to believe that it was chain noise reflecting back up into the gearbox.
I checked for tight spots, or stretch. I tried different amounts of adjustment slack, between the minimum of about 20mm out to about 60mm, replaced the outrigger bearing, check the wheel bearings, alignment, new clutch and rear wheel cush rubbers, ect ect. Nothing seems to resolve it. It really sounds quite harsh.
Not long ago I had it on a dyno and I could see the chain "vibrating" at times, and at other times it ran without vibrating. Vibrating. Lets say it's a high frequency oscillation between the extremities of the adjustment slack, which correlates with the noise.
By 3000klm I couldn't live with it any more. I stripped the motor again to look for damage, wear, or any kind of evidence marks, and to check shimming. Nothing out of place, but I have fitted it with completely different gearbox internals and clutch. Unfortunately other issues have stopped me from putting this bike back on the road.
Instead, I had a 2nd of 750S in the shed with zero klm on a rebuilt motor (another crank rebuild), so, again, gearbox with about 20,000klm on it. So I fired it up, and after about 200klm I can hear the same thing just starting. But then I am quite sensitized to this issue at the moment.
The vibration, or high frequency oscillation, is, to me, a harmonic being caused by something.
Both bikes have 520 chains that don’t demonstrate stretch, a DID zvmx, and Japanese unbranded 520. The first is running 15/43 gearing, the 2nd 15/40.
They only thing I can think of is to try and break the harmonic by using a different gearing, I have a 16/48 combo I could try. Or a different weight chain.
Any ideas or advice? Someone must have suffered this before….
Thanks! Greg
Thanks! Greg
