martymoose
- Sydney, Australia
Does anybody know what is the correct size, I have 4 mm and 3.5mm.
I'd go up a size in any case. Original 3C wheels are a bit flexy.are you not supposed tpo go up one gauge if using stainless spokes? just a thought in case......
Its such a specialized build these Laverda rears so take care out there.
I should think that they need to flex.I'd go up a size in any case. Original 3C wheels are a bit flexy.
Hey Marty, are we talking about the bike you just took around Oz? Did the wheel suffer some damage during the trip?
Oops, sorry. I shouldn't mention spokes. Somebody got offended when I last made a comment about a spoked wheel.
I haven't looked at one of these but I'm guessing that this approach is used with tubeless wheels, it may allow the spoke tension adjustment to be made at the hub instead of the rim, making it easier to seal the rim so the air doesn't leak out.I haven't made a study of the hubs on other spoked wheels, although I've noticed that there's a trend more recently for spoked wheels to have the holes drilled radially in the hub, so the spokes have no bend at all. Moto Guzzi and BMW are examples that come to mind.
Why? Nobody wants a flexible wheel. Not even on a wheelbarrow. The only flexible part of the bike should be the suspension. Cast alloy wheels were invented to improve rigidity and make them more reliably circular.I should think that they need to flex.
You may be right, but something has to flex. Racers often complain that the cycle parts are too rigid. If the wheel doesn't flex, forces are transmitted elsewhere.Why? Nobody wants a flexible wheel. Not even on a wheelbarrow. The only flexible part of the bike should be the suspension. Cast alloy wheels were invented to improve rigidity and make them more reliably circular.
It was the late, great, motorcycle racer and engineer Peter Williams who is credited with inventing solid cast alloy wheels for motorcycles. His wheels made their public debut on the race track in 1970, fitted to his Arter Matchless dubbed "Wagonwheels". The reason he did so was to create a stiffer wheel with less run-out than the spoked wheels of the day. He wanted greater wheel rigidity because his wire spoked wheels were flexing when heeled over in the undulating corners of the Isle of Man TT course, sending the bike off-line. With the stiffer mag wheels, he could hold full throttle through corners where he couldn't previously.
It was rigidity rather than weight reduction that he was trying to achieve initially, although I'm sure he was aware of the potential for light weight from the outset. I remember seeing a photo of his first set of prototype solid wheels in a bike magazine many years ago. I have a vague recollection that they were fitted to a Norton in 1968. I can't find that article or picture now, but the wheels were quite chunky with 6 massively thick spokes like flanged beams. I think the article said they were actually heavier than the wire spoked wheels they replaced, but a whole lot stiffer. It was only through design refinement in subsequent years that they became lighter than spoked wheels.
