I fitted Bridgestone bt016, i have wider rims than standard. Rear is 4.25 and the front is 2.5 so tyre sizes are 150/70 rear and 110/80 front. They are not the longest lasting tyres but offer astounding levels of grip wet or dry😀👍.
Tom
  • Like
Reactions: Jo
Tom
Hi Tom, Phil from Vic here.
I know you had the BT016's previously and then you tried something else recently.
Obviously no better and back to the BT's.
Only curious as I need new ones soon.
Refitted my repaired stator to the Mirage which is now charging as it should. Got the charge/Gen light working properly and also fitted an LED headlight replacement bulb: very impressive. The headlight vibrates around quite a lot and I think I'm in need of new silent blocks which support the headlight unit: does anyone still supply those??
Thx
AndyW
Hi Phil. Did try another brand but had big problems with chain clearance. Had to rasp off a lot of the edge of the tyre to get clearance for the chain🙁. Ended up not liking the fact that I’d removed so much off the tyre so ended up swapping it out for a 140 to get clearance for the chain. That tyre was a Dunlop Roadsmart 4 and the 150 and the 140 were very good tyres, no problems with grip wet or dry. The 150 was a very wide tyre and the chain I’d had fitted at Oro’s in breganze was a heavy duty 530 so was quite wide. Since swapped tha chain out and have done a 520 chain conversion, brilliant change as much lighter and a lot less snatch on gear changes.HTH.s
Tom
Thx
AndyW
Silent blocks are generic M8 available from all industrial suppliers.
My headlight is solidly bolted on the frame welded fairing mount with zero rubber cushioning and I guess that's not ideal. I can see some more rubber grommets in my future.
Not normally...
The headlight "ears" are nicely rubber-mounted to the stanchion shrouding tubes, more than ample vibe isolation.
1 more lesson learnt. I'm so used to my SF2 which of course has the one piece headlight mounts that I naturally put some silent blocks on my 3C. I don't think they'll do any harm.
Except unnecessarily daze oncoming traffic with the headlight bobbing up and down far more than it needs to. :rolleyes:
And it looks terrible...
Not normally...
I think it might be those nice rubber mounts I’m after… mistakenly thought all rubber mounts were called silent blocks 🥹🥹
Drove 470 miles, today, to drop the forks off at Maxton's and exhausts for re-chroming, with Malcolm.
Already suffering withdrawal symptoms, knowing I can't ride the bike till the bits are back. Sadly, I don't have spare sets, in stock.
The wait commences,...
