Legs
- Adelaide Hills
A god place to start would be deburring those spines, reckon with the engine spinning there is just enough friction to lock up the plates. If nothing else it would eliminate one potential cause.
That might be part of the problem.While it is apart check that none of the plates are distorted.
I think you will find that your Ducati dealer has installed a plain plate between the first two lined plates, that item should not be there, you can ditch the anti rattle sporings completely, they dont do much anyway, are a pain to install and you need a special tool (idealy) but you dont want to increase the thickness of your stack, (can cause dratg) there is no need for a plain plate between the first two lined pates unless its not a road bike. Some people fail to understand that these two plates rotate together at all times and there is only slip between the lined and plain plates.
Getting neutral at a standstill can sometimes prove difficult, if this happens to me, then I simply "take the load" with the clutch lever partially released and then I can snick neutral, the wheels might rotate 5 degrees when I do this, so try it!
That is crazy. And you say it isn't new ?!<snip> Before, when I would start the bike and put it into gear, it would lurch forward and stall, presumably because the clutch plates were sticking. It would do this once, maybe twice, depending how long it had been sitting. Now, it does this a half dozen times, or more, and it is much more violent. <snip>
Here is the witness mark of the lurching forward.
Quote from the workshop manual:Looks like your up for a new ball and push rods <snip>
Nothing like a good dressing in case of fornication Clem.male segments on inner clutch hub look cattle trucked, and we dont see a picture of the internal splines on the outer, they may be fornicated as well, some dressing will restore use,
Won't/doesn't hurt, altho' I use paraffin rather than white spirit (and certainly NOT 'turps' as in "turpentine").Would it be worth cleaning the clutch plates with turps? Roughing them with some sandpaper?
