After a week of summer rain the sun came out at last, and I was able to try out the new clock and voltmeter 👍
Humidity was through the roof, so half an hour and 26kms was enough, but also a good shakedown to ensure that my new fusebox and associated “wiring improvements” weren’t likely to cause problems 😁
Everything worked as expected (praise be) so feeling good for the upcoming adventure to the big Burt challenge (y) :D
P.S I had to make a new panel to accept the fusebox, RR and ignition box, which was a bit of a challenge with all the different levels, if anyone wants a template let me know (y)
Just wondering, how accessible is your fuse panel? Looks to be on the inside of the rear frame area.
cheers,
bazzee
nice to see you mounted the reg/rect with the fins vertical, why dont more do that, it is thermally far superior, and the fins are there to dissipate the heat, if they are not in a directmoving airflow, then thermal currents come into play.
A long time ago in a country far away (PNG), I was modifying an adventure bike before they were invented and mounted the rectifier in the air-box, guaranteed a good airflow in there.
Hamish, I don't think I could find a shop in Germany that puts contaminated exhaust parts in their chrome bath. Perhaps Piet knows more.
Gerald
I had heard that due to the risks of the chemicals used, that chroming no longer exists in germany at all
Piet?
bar room bollocks probably
Piet?
That's a bit exaggerated Clem.
Waste disposal is the big issue. The traditional stuff can only be applied under very strict environmental restrictions. This brings about additional costs/expense that not all are prepared to carry. A slightly less toxic chrome-type product is now widely offered, as always, nowhere near as good as the good old stuff. Somebody better at chemistry than me could probably explain better.
Lots of small galvanisers of all sorts have disappeared here due to environmental restrictions. Good thing in many cases, lots of those were literal hell-holes.
Chromed car spares and accessories seem to be outsourced from all over the world, where restrictions are either not as strict or non-existant. Mercedes Benz bonnet stars for example have been manufactured in Turkey for many years, I suspect waste is probably dumped in the local creek... not really sure if the western "civilised" world can afford to support that sort of stuff for much longer, the results are plain to see and end up on everybodys' shores.
Chromers here are quite anal if you show up with used exhaust parts. But, top quality shops will do them, no problem. Just have to pay, it has become REALLY, REALLY expensive. Rechroming a single triple silencer costs considerably more than a complete new system.
Super neat. Nice job Andy
