"In my experience if there is a restriction in flow at the top end its nearly always fuel taps."
from Paddy above.
I can confirm this, when I was racing my 1200, the top end fuel starvation would show if the circuit had a long straight (eg the old original Snetterton, with its near one mile long straight) but any long straight, I always geared for max revs to come just after half way down the longest straight of any circuit, but maybe three quarters, this is when it showed up and starvation showed, it was very different if running a full tank, racing fuel consumption was (IIRC) around 18MPG it was very rare to run a full tank, as I made sure there would be next to zilch left at the end of whatever the race distance was, and this was while using 300 size float valves, I solved that by welding in an extra fuel tap boss and fitting a third tap, each carb had its own tap with carbs 1 and 2 linked and 2 and 3 also linked, I ran like it on the road for a while, and it cured the stutter when getting close to reserve, when you could (in the old days) ride at 100MPH with not much risk of a ticket, to all intents and purposes anything over this speed is a real hard chore, so it doesnt get done for more than a few seconds. these days, I get the same feeling at 80/85 that I did in the past at 100, that is me not the bike.
