Slippery Sam was a production-based bike, did not use a Rob North frame. Mind you the standard frames use lugs and they would certainly be brazed. Not the most modern technology.Didnt they braze those Rob North frames?
I shall stay optimistic Clem. If the heat didn't melt alloy, I doubt that the frame suffered.The Laverda triple frame is made of gas barrel and stick welded, shouldnt be any worries there Paul, at least welds wise, the top tube may have got unbearable hot and expanded createing some issues, because other areas of the frame remained cold, maybe distortion, maybe alignement., maybe heat affected metal
Don't forget to fix the clutch.I shall stay optimistic Clem. If the heat didn't melt alloy, I doubt that the frame suffered.
Just a case of paint stripping.
Since the engine will be apart, I'll check the whole bl..dy thing thoroughly, again, and drill a hole level with the primary compartment floor into the gearbox.Don't forget to fix the clutch.
The bloke who invented Computrack,Greg Mc Donald is from Australia and used to race Laverdas for the Oz Distributor. Even though the Company is based in Oz at first you could get it done in Sydney but for years they had no presence here. They now have a Rep in Cessnock NSW and I had my 3c measured about 10 years ago. It came out ok, no work was required. The last I heard Greg was working on Moto 2 Chassic designs.If you are worried, send it to a frame shop to be checked and aligned. Is there a Computrack shop to measure it in Europe?
Parts in Process
No need, Just a couple of cones on broom handles.If you are worried, send it to a frame shop to be checked and aligned. Is there a Computrack shop to measure it in Europe?
They were all over the place apparently, but were still miles ahead of oriental builds of the time.When I owned the Computrack franchise in Los Angeles I measured my RGS and found it to be dead straight, no need for any corrections at all. I have no idea what the earlier models were like as we never got any in the shop to compare.
