Tying down a bike for transport
I reckon your fork seals were already knackered then Chris.
With our old Marzocchi or Ceriani forks, when a bike is parked with barely any load on the suspension, there's practically no pressure inside the forks, so even if the seal is worn out, you won't see much leakage. But when you crank down on a set of tie-downs to compress the forks for transport, you'll create pressure behind the seal. Sustaining that pressure for hours on end during a lengthy transport will naturally make the seal piss out more oil than it would during normal use. It doesn't mean the seal is "blown" though. It doesn't even mean it's in worse condition than it was at the start of the trip. All it means is that it's a leaky seal.
Shaft seals generally work in two modes: rotation, such as in a gearbox or engine; and reciprocation, as with hydraulic rams or motorcycle suspension.
Seals on a rotating shaft have an easier life than reciprocating shafts and usually last longer, but we're not concerned with them in this instance.
Reciprocating shafts can drag dust and grit into the seal as the shaft retracts. Some fork seals are designed to minimise this problem by having a double lip, two seals together, or an external dust cover that wipes the shaft clean. On forks like the old Marzocchis or Cerianis on our Laverdas, there's a space between the outer dust seal and the inner oil seal. Some owners will stuff a bit of oily rag in there to add another level of dust protection for the oil seal.
Another problem with reciprocating shafts is that the shaft has to be in perfect condition for its full length of travel through the seal. Motorcycle forks are rarely in perfect condition. There can be stone dings and other damage that can have raised edges that tear at the seal lip as they pass through.
The result of all this is that motorcycle fork seals are rarely in perfect condition. If you hold pressure on any bike fork seal, it'll probably leak. I believe that's the reason for the belief that using tie downs to compress the suspension results in blowing seals. As Haggis eloquently states, it's "bollocks". In my opinion, there's no way that compressing the suspension can cause any damage a fork seal.
The inescapable truth is that the suspension is designed to compress and the seal is designed to withstand the pressure. Whether the pressure is for a short or long duration makes little difference to the physical state of the seal.
The only way a seal can actually blow out of the fork leg would be as a result of incorrect installation. For example, if someone forgot to install the retaining circlip, or if it wasn't seated in its groove. That's something you'd definitely want to know about before riding the bike, so the seal popping out during transport would be a good thing.
A possible exception might be AndyW's experience with transporting Triumph T140, T150 and T160 bikes across the country. Those bikes have no circlip to retain the fork seal. All that holds the seals in the forks is friction. I suppose under constant pressure and vibration they could work loose and pop out. But in my opinion, that's poor design. A heavily loaded bike will have its forks compressed under the load. Riding it across the country would provide a similar or harsher environment than Andy's trailer transport as far as the fork seals are concerned. I'd be worried about the seals working loose during use.
Well, those old Triumphs leak oil from every other join, why not out of the forks too?
A oil puddle somewhere is to be expected.
I’ve been considering this point about taking the suspension out of the equation because I don’t like the idea of any load moving after I’ve tied it down. I saw a bike recently being tied down and the owner had made a special bracket which fitted between the stanchions and the lower triple clamp. He said it worked well, and he could tie down as hard as he liked from the triple clamp.
Not sure about tying down directly from where the forks slide into the stanchions, it seems like pulling the forks apart like that may bend something. I don’t think that angle of force is seen in normal service so damage may result?
Thats easy on a Dirt bike, plenty of room. I had a purpose-made alloy thing with rubber top and bottom I bought but it disappeared so we started using empty 4l plastic oil containers. With the close-fitting front mudguard on Road bikes, I don't see that happening.
I’ve got one of those spacers too. Fine for dirt bikes. My ZX7R have disc rotors that almost rub against the inside of the forks, even getting a strap through the gap is impossible.
I made up a round bar, treaded both ends and female threaded eyelets screw onto each end once the round bar is through the axle hollow. Tie downs easily work with this bit of fabrication, solid too.
Pointless if the axle is solid, like a Laverda 🤔
I have used Dellortoman’s method for many years. The only caveat is bikes with air forks. I had a CBX blow oil all over everything after five hours on a trailer. Now I release any air in the forks before trailering.
I had one moved by a pro transporter once, both loops low as possible to the front axle, tie downs forward from there. I questioned it, he explained, no fork bounce, no fork sag, no blown seals, can tighten straps as tight as you like.
Mind you, I’ve never seen them done like Robs though
Makes sense to me
I had a similar experience with a local bike carrier, loops attached above the brake caliper mounts on the forks.
I would also strap the rear of the bike down for extra security.
I am agreeing with Cam, and I have been doing this for more than 50 years, in the begininning with rope and if you can'nt do a truckers dolly knot then dont use rope!, 25mm straps with ratchet tensioners changed things for the better, I am a bit blinkered on Laverda and dont have too much ecperiance with other makes but my Marzochi forks have springs and balls in the top nuts to release any over (hydraulic) pressure, but the thing is this, on cars, trailering of which I also do a lot of its usual to strap the wheels down to the deck, this is commonly seen and does not compress the suspension it is the preferred method,, this works very well for bikes as well, but it is difficult to achieve because inevitably there is a clearance issue and you can't "get at" the wheels properly, tying down to the bottom yolk is getting more common due to fairings etc, TOG is tied down to her handelbars which is part of the design when I made a new set decades ago and another set more recently, they resemble Jota bars but solid welded and in a position/width that cannot be achieved with the stock items. Strap condition is important as well, I am notorious for using stuff that is past its best before date, on a trip to Italy I had a front strap break, fortunatey the rear straps held it, which is why I always use four straps, a small nick was present on this strap and when a hard bump (realy, realy, very hard) caused the forks to compress and momentarilly loosen , the rebound of the forks snapped the strap, my fault, should have replaced it, and on the same trip, a wheel came loose on the trailer, (mini 10") due to the fact that the steel had been getting proigressivey thinner due to rust over many years, and the nuts had started to "pull through" the steel wheels, not helped by the massive bang, two studs snapped and gone, one remaining with no nut and a single stud wich was loose, the noise told me I must stop, this was repaired by removing a good stud/nut from the other wheel, leaving three, and tighteneing the loose one and installing the robbed one, so two studs, we did about 150 miles to a pals house in Switzerland where we improved the bodge using 10mm bolts and nyloc nuts (should have been 3/8"UNF) and then made it the 600 miles to home, it turned out that new tyres with fitted new wheels where cheaper than just buying wheels (no sense to that) but its probably good for another 30 years now. all 8 studs were renewed and new nuts at the same time, all nuts are now lockwired, which I also recomend, mainly beacuse a very quick glance gives you a visual on anything going wrong. I also carry a very small gease gun and on long trips of say 500 miles, I give each bearing a shot oir two of grease before returning, that trailer has done 3 trips to Breganze (1,000 miles one way) and 4 to Spain 1,200 miles one way.
My trailer has 10" Mini wheels too. Good steel Mini rims as rare as hens' teeth in Australia. Mine were looking a bit secondhand last year so I was looking around for replacement options. Couldn't find any original steel rims on eBay at the time. I did notice on internet that you could buy new steel wheels with tyres in UK, but transport to Australia was way too costly. The only thing I could find here were flashy mag wheels with wide tyres - a bit OTT for a bike trailer. I ended up refurbishing my old wheels. De-rusted, straightened and epoxy painted them. Had 3 new tyres fitted and balanced (2 on the trailer plus a spare).
The wheels look a whole lot better now with the white epoxy paint and new domed chrome wheel nuts. Now I'm thinking the wheel bearing caps look like shit.
Also note the well secured bike (staying on topic). Sorry, crap photo but the best I could find with the newly tarted-up trailer wheels.
BTW, a mate told me that tie down straps should have a twist in them to stop them fluttering if they're edge-on to the wind. He said that tip came from someone in the transport industry. Sounds reasonable to me. Has anyone else heard that advice?
No, but I have seen them flutter like flags at speed. For the first few years, we used ropes and Truckies hitches, that took hours to tie down 4 bikes. I haven't heard that called a Dolly Knot Clem and then cheap teardowns made back then out of what looked like orangy brown car seat belt material. The craziest gadget we used was supplied by an ex-Army bloke. He had an Aircraft type ratchet strap used in Hurculeas Aircraft approx 100mm wide. We used it across the seats of the 4 dirtbikes we carted often, It was so powerful it bent the trailer together.
I have heard that tip Cam but I never employ it, what catches out amateurs who have lost their bikes either in the back of vans or on trailers (not mentioning any names except Adam S, Terry S and Andy J, is this, each of the four straps must have a double turn at either the deck end or the bike end, a 360 degree loop looking like a diagram of a speedway circuit is useless, using one strand of strap with a hook at both ends works, but a double length of starp with what is called a clutch at one end is twice as strong, thids is with the two hooks of the strap locking to each other in mid air, two lengths of strap taking the strain instead of one. Also means you always have fabric on your bike and not a metal hook.
I converted mine to spring-loaded carabiners and use that soft connection as well. Open hooks can pop off if you hit a big enough bump, I know it's unlikely but it wasn't expensive. Carting Dirtbikes down long firetails with erosion humps, mitre high humps across tracks on big hills to stop erosion in big rain. Very easy to get air if you hit them fast enough and launching a bike off a trailer is very easy doing that. I was looking for a picture and found this, its no were near as abrupt as some I have been over. BTW we once got caught in a Thunderstorm on a track with no humps, it turned into a downhill flowing creek immediately and we were bloody lucky to get out at all.
it may be Cam, at the top I can see a 180 degree loop of strap, at the deck I cannot see it, in this case there should be a 540 degree twist of strap at the deck, it matters not if top or bottom, but if there are two 180 degree strap ends it is totally reliant on the strap the other side of the bike to prevent movement, if you have a 540 degree end (clutch) that end cannot slide, the other end can as tension is taken up, making both straps sides do the work.
