Dellortoman
- Tasmania, Australia
Nothing goes to plan, eh Vince. Not even the simplest job.
Sorry to hear that the right-hand grip heater is buggered. I see online that you can buy the grips separately, so you don't have to buy the whole kit again.
Perhaps next time, remove the throttle twistgrip tube and use a press or draw-bolt to get the heated grip on. It's a bit gentler than whacking it with a lump hammer. But if you're having so much trouble getting the right-hand grip on, maybe your throttle twistgrip tube is a bit oversize. According to the installation blurb on YouTube, the Oxford grips are designed for a 1" throttle tube. If yours is fatter than 1", try rubbing it down with sandpaper. They actually suggest doing that with some bikes, as well as removing any lip on the end of the throttle tube.
If the glue is giving you trouble, maybe you could get the grip on first then glue it once it's in position. It should only need a few spots of glue to hold it. Once it's on, poke something thin (long skinny screwdriver blade?) down in between the heated grip and the throttle tube to make a small gap. Dribble some superglue down the gap and yank out your screwdriver before it has time to get stuck. Do that in a few spots and it should be pretty well stuck. Obviously you'll need to do that from the outer end because the cable pully will block access to the inner end.
Just tossing around some ideas around. They might be rubbish.
