piranha-bro2
- Melbourne
Have to chip in here. The family Skoda Scout 4WD has a heavy metal bash plate under the motor/sump. It's big and it's very heavy and I hate removing it - necessitates removal for every friggin oil change. I made a cardboard template of where i can grind a V into it so I can simply remove the drain plug, but never got around to doing the mod - i simply left the thing off and it's been off for the last 5 years. If I head bush and I'm gonna be scraping the Skoda's knackers on the deck, I'll put it back on - but not before I grind that V into it!
I've got the Redax drain plate and mag bolt on the SFQ - the bolt head is JUST a tiny bit too deep to allow the bolt to clear the X pipe under the motor. While I had the bolt out i ground a few mm off the head and hopefully I'll be able to remove it completely next oil change. Alternative is it sits in place and allows oil to drain past but it takes about an hour and a half!
I'd go for it Vince and bore the hole and add the tidy tube. Piss easy job and once done, done forever. And FWIW, no way I'd be changing oil unless it was 4000km of heavy stop start summer city traffic.
