martymoose
- Sydney, Australia
Your choice Paul but many people with many bikes of all makes have been stuck with shit contact in key switches, and it is dead easy to identify a failed relay (same Bosch mini relay on my bike since late 70's) and bypass it.You're lucky but if you hadn't modified a perfectly functional bike, you wouldn't have broken down.
They don't need relays, M gadgets and all those excuses for breaking down.
And get rid of any sign of corrosion on the outer side as well.Buffed the bejeezus out of the rear rim and hub from the 3C before I fit the new spokes
I've had it happen several times, including 3 times in the last couple of years.Your choice Paul but many people with many bikes of all makes have been stuck with shit contact in key switches, and it is dead easy to identify a failed relay (same Bosch mini relay on my bike since late 70's) and bypass it.
As far as I am concerned it is what people call a no brainer.
Bugger, now you’re going to have to polish the front oneBuffed the bejeezus out of the rear rim and hub from the 3C before I fit the new spokes
Could the spoke have been too strong? There may not have been enough give under hard shock loads causing the thicker spoke to fail. I have seen this in bicycles where heavyweight spokes have broken repeatedly, but when replaced by a smaller gage the failures stopped. Counter intuitive, but it has been known to happen.New spokes from Wolfgang zinc plated ones, correct, 2 different types. New ones are 4mm, old ones where 3.5mm, it was laced properly, but extra weight(who you calling fat...). Possible cause of spoke failure on the round Oz trip. Only 1 broke though.
True about bicycle spokes and sizes (hence double butted) but a lot of breakages I'ver seen (i've worked in shops for decades) are the result of nothing more than crap quality spokes.Could the spoke have been too strong? There may not have been enough give under hard shock loads causing the thicker spoke to fail. I have seen this in bicycles where heavyweight spokes have broken repeatedly, but when replaced by a smaller gage the failures stopped. Counter intuitive, but it has been known to happen.
Bit harsh, Mr Marx. It was a modification that Steve Winterton used to do, based on his experience - which is considerably more than mine.You're lucky but if you hadn't modified a perfectly functional bike, you wouldn't have broken down.
And mine.Bit harsh, Mr Marx. It was a modification that Steve Winterton used to do, based on his experience - which is considerably more than mine.
Oops, that was about ten years ago
I reckon you’ve probably worn yourself out “reminiscing” over that memoryOops, that was about ten years ago
But the beer girl showed me the pictures from that day at lunch today![]()
