Fuckin' good idea, Lee! Got lots of merit to it.Oh no! Piet will sell them and retire in luxury, never again having to fix other peoples Laverdas.
Good point,I always thought the tightening up procedure of the front axle/forks was a complicated affair on the triples?1mm would be fine, but the calipers must be perfectly centred. Have you centred everything on the axle by bouncing it hard against the brakes before final tightening of pinch bolts etc.
I have been surprised how thick Mals discs are, they look massively thick to the eye.
As Tippie said - 'Yes'.Or is 1mm free play acceptable
Why should that be too tight? How do you want to go about increasing it?Possibly I'm in error here, but 1mm gap between solid mounted rotors and brake pads is too tight- if they were floating that would be a different story. According to Bevel Heaven, the earlier Ducati versions have no logo and mine have the Brembo logo. I've ordered the shaved EBC pads from Paddy. Again, I've just received this bike so I'm unsure about it's full history, and looking down into the open caliper, it appears one side is slightly closer to the rotor. At some point I'll look into newer/lighter/thinner rotors, but for now this will do, and I've got a few other things to correct on this bike.
Thanks all for your input!
Nah, it is 1 kmh according to the road safety ads here. Speed limit = safely stopped with metres to spare, 1k over and the car is an unrecognisable wreck smashed into a tractor.1mm is the difference between life and death when that car pulls out.
I think you are in error. Gap between pad and disc is quoted in the 750SFC handbook as 0.2mm, shown measured with a feeler gauge. (There are several other tolerances quoted for parallelism, runout etc below). I think a similar figure also appears in the early triple workshop manual/handbook. As Piet notes, old seals lose their flexibility and reduce the 'pull back' of the piston when brake lever is released and this gap will be less.1mm gap between solid mounted rotors and brake pads is too tight
Think?As Piet once said to me, don’t overthink it
Get some platform shoes and put yer feet down?Think?
