pf1
- Portsmouth UK
I use Hylomar, works fine.
No idea if my green gaskets came from Athena, but ... lucky you. I'm decidedly unhappy with whatever these green ones are. In 50 years of ownership I've never had gaskets leak. If I could get original ones I'd jump at them.I've no problem with the green gaskets from Athena.
Neither does Keith Nairn.
Many of the flatter engine covers are horribly warped by now, especially the small RH shifter cover and the 750 primary cover. This is very often due to the over-exuberant but futile attempts of DPOs over-tightening the fixing screws to stop yet another leak... instead of fitting a new, un-squashed gasket. The softer the gaskets are, the easier it is to distort the cover, the 2 beforementioned covers are not at all stiff and will distort easily under slightly uneven pressure at the screws. The more give the gasket allows, the more distortion will occur.Some of the green gaskets now supplied are as hard as metal from new, unlike the original grey ones from the factory. I have checked engine covers on a glass plate and can find no warpage, despite them dripping oil with new gaskets. The only way I have got them to seal is with a minimal smear of silicone (I will try to get some of the Loctite but it isn't readily available here) and letting it cure over night before filling with oil. Using silicone and then filling with oil had it still leak.
In the 40 plus years I've owned Laverda motorcycles, every time I bought some parts from Phil Todd who lived a couple hours drive away plus one cross Channel ferry, I'd buy a complete set of 750 gaskets.No idea if my green gaskets came from Athena, but ... lucky you. I'm decidedly unhappy with whatever these green ones are. In 50 years of ownership I've never had gaskets leak. If I could get original ones I'd jump at them.
Aka master gasket aka strawberry jamHave you tried Loctite
Hylomar just brings back memories of it oozing out of all the gasket surfaces on British bikes back in the day, still dripping oil. Maybe it is better today.Especially Hylomar should be applied sparingly, it washes off easily but doesn't dissolve, excess can clog the oil strainer quite effectively. Same goes for all silikone-based sealers. Loctite 518 usually does the job, but sometimes silikone is the only solution...
I think that says more about the tolerances and ham-fisted spannering on many of those bikes than about Hylomar. Been using it on metal to metal joints on cars, bikes, etc. for nearly 50 years and trust it 100%. Knew a couple of Rolls Royce Derby engineers in the’70’s/80’s who used it on gas turbines. And their bikes.Hylomar just brings back memories of it oozing out of all the gasket surfaces on British bikes back in the day, still dripping oil. Maybe it is better today.
Loctite 518 is about €100 incl post for 50ml here. Better than an oil leak though.
I’ve only used blue. They used to use Stag at sea on steam pipe flanges for example, and on motor ships too, probably on all services.Hylomar was recommended by Rolls Sealer. Isn't there a Blue or Green? That Loctite 518 sounds like the best. For the first engine rebuild I had done, 64 Bonnie the bloke used STAGG absolute crap, I was scraping it off stuff for the next few years. It set like glass, brittle and hard, ended up in the oil stainer and the bike still leaked like a sieve. It's pretty well known but always a good idea to check for gasket goo in the bottom of the cover fixing bolt holes. Bolts don't work well if they bottom on that shit before the cover clamps up tight. I know everybody already knows that but some might not. Simple stuff gets missed a lot. Q maybe look at engine case pressure and more breathing ability?
It was red Hermetite people used to splodge all over british bikes as I remember, Hylomar was way too expensive.Hylomar just brings back memories of it oozing out of all the gasket surfaces on British bikes back in the day, still dripping oil. Maybe it is better today.
Hermetite- curious smell, goes hard, looks shit ,doesn’t work.It was red Hermetite people used to splodge all over british bikes as I remember, Hylomar was way too expensive.
I use Loctite 518. I've no idea of the price, I'm still using the syringe I bought in the 90s.Hylomar just brings back memories of it oozing out of all the gasket surfaces on British bikes back in the day, still dripping oil. Maybe it is better today.
The odd drip from the primary cover while sitting cold in the shed - no crankcase pressure. it's very minor and i could live with it but it shits me, because it's unnecessary.Q maybe look at engine case pressure and more breathing ability?
