a14rgs
- Wiltshire, UK
- here's one that Alan currently has available...Alan Bell had some good used ones, otherwise you are whistling in the wind.
Dear a14rgs, many thanks for your suggestion regarding eBay; I've made contact regarding that second hand item. I'm also looking at a NEW replacement item from Germany via 'ocTeam'. Their new replacement item is cheaper than the one on eBay, but needs a modified 19mm box spanner to install it (the original part uses a 17mm Hex). Thanks again.- here's one that Alan currently has available...
Keep us updated, please.Dear a14rgs, many thanks for your suggestion regarding eBay; I've made contact regarding that second hand item. I'm also looking at a NEW replacement item from Germany via 'ocTeam'. Their new replacement item is cheaper than the one on eBay, but needs a modified 19mm box spanner to install it (the original part uses a 17mm Hex). Thanks again.
Hi, I'm in Southampton to, been looking into the neutral switches myself... There non existent unless you want to pay £100 for one on motalia.I realise this string about the supply of a Neutral Switch for Laverda 1000 is some years old now, but I am having difficulty sourcing one for my 1981 (180) Jota. Do you still have any available? I'm in Southampton.
Alfa romeo switch worksHi, I'm in Southampton to, been looking into the neutral switches myself... There non existent unless you want to pay £100 for one on motalia.
Anyway I ve ordered a switch same 14 x 1.5 thread Hopfully have some luck with it when arrives. May be we could catch up some time there can't be many of us laverdas around here.
Regards Keith
My 750 blew up the starter. I will never forget the noise it made turning for a second with somehow very high revs. The starter clutch conected with the starter during the ride. But it wasnt for shure the starter switch. Some of the rolls inside the clutch might have made the conection. The starter had dents from inside out. Very impressive look.Pain in the arse if you stall at the lights too. Gotta shift back into neutral before you can re-start.
Also makes the bike practically unrideable if you break a clutch cable (need to start in gear to get off the line). I'd rather not re-wire the bike just to get home when a clutch cable breaks, which has happened to me on several occasions over the years.
I've never blown up a starter motor, and quite frankly I can't see how locking out the power supply to the starter when the bike is in gear achieves anything. The sprag clutch prevents the starter motor being driven by the engine. If you hit the starter button with the engine running, so what? The starter motor won't spin fast enough to catch up to engine speed and engage the sprag clutch.
On those rare occasions when the sprag has seized and destroyed the starter motor, I very much doubt it was caused by hitting the starter button whilst riding the bike.
The clutch interlock for the starter on my 'modern' bike annoys the crap out of me too. The starter will only work if you pull the clutch lever - even in neutral, which pisses me off.
As you can guess, I'm not a fan of idiot-proof interlocks. I don't like machines that do the thinking for me. I already know that I shouldn't press the starter while cruising along the highway. I don't need a set of relays to tell me that.
I don't like automatic transmissions for the same reason. Don't get me started on automatic windscreen wipers, headlights, etc. It's the thin edge of the driverless vehicle wedge.
End of rant. Sorry.
