Shajota
- Whitsundays Qld
Hi Michael, no we rode to Lake Proserpine which is much much smaller and just west of Proserpine (and quite a small catchment).Is this the lake/reservoir we rode to when I was over there? Is there really 6m of water pouring over that spillway?
As you can see from the map, this dam is also due west however no direct road so you have to go up to around Ayr, head west and then back down to the dam which is over 420kms or considerably further if you wish to avoid the dirt..............
And yep, really 6m over spillway. If you look at video you can see water is not only over spillway, it is up to the actual ends of the dam you can see in my pic taken in the dry.
BTW, you can drive down to the dam and drive across in front of the spillway which links to a road heading south which is quite rough and 4wd only. Just to be annoying I have attached another pic (which might show it better) from the bottom of the spillway where you can drive across.
Of course it was hot so we walked down and across instead!!! And one from below looking toward dam which might show better how big the raging torrent is (Edit - Should have said - Spillway is 504m long.)
