Stubborn 750 cam chain fitment
once you get the bottom two bolts out it's dead easy to pivot the motor sideways and drag it out - you can even drag the rolling chassis sideways to leave the motor sitting ready for more love.
Of course you guys know what you're talking about- I was hoping that the engine could stay in place. I tilted it up almost vertical, and still getting spaces between the chain links- no matter how I giggle and lower the chain ends into the case- it's hanging up somewhere from the bottom sprockets even though it appears to be engaged. I've snugged down the barrels and the tensioner of course is not in place w/ plenty of wire to prevent the chain from slipping into the case. The problem with removing the motor is that I'll be tempted to paint or powder coat the frame-
Get it running reliablely first. Then strip it for powder coating when you're happy how the bike/engine performs. That way you only need to put the engine back in the newly coated frame once. At the moment you don't know how the engine is going to behave after the re build. It may have to come out again for more work.
Repeating.....it is not easy with the motor tilted off vertical, there is usually somewhere it hangs up. If you have to do it like that, get someone to help, firmly attach some strong wire to each end and get your helper to pull up hard while you rotate the crankshaft backwards and forwards about 90 degrees and it will suddenly jump up and you can get it onto the cam sprockets, but you are working against yourself.
Thanks Tippie,
I raised the motor back to level and see that the chain won,t bunch up In the back near the idler wheel as it did while tilted, but the chain still has a 2 teeth gap no matter how I giggle the chain ends w wires attached. I,ll get someone to help advance the motor back and forth while I pull and giggle on the chains
Have you taken the motor out yet? I think everyone contributing here is somewhat baffled that you're persevering against all good advice! :cool:
Seriously, whatever is going on 'down there' is odd in the extreme and you need to have full access!!!
"I see a separate sprocket but its off to the side"
this is a two row chain and (obviously) the crank and camshaft has double toothed sprockets, the chain (at the crank end) should be on both rows of teeth, you do have a duplex (ie twin row) chain dont you?
I very strongly think that you need the physical help of a mechanic who knows Laverdas.
Thank you all, especially Tippie, since advancing the motor back and forth while firmly holding onto the chain ends finally set the chain in place.
I see that the chain is fairly snug pressing thru the tensioner opening and I have a feeling that the tensioner was pressing too tightly against the chain since the bike came to me w the tensioner locking nut loose. The tensioner roller was worn and the rubber cushion was hard and both have been replaced. The next step is putting this back together and seeing if new pistons and valve job have improved the engine performance.
The 'half' teeth Teddy is seeing is where the machining of the sprockets was made from the side. The cutters come in from the side and cut the pattern into the centre piece journal that butts up against the inner race of the main bearing.
Great!! Success, Teddy!! I trimmed my tensioner rubber slightly to avoid excessive tension once fitted - but Tippie's idea of two gaskets is better.
I've got this to come - my brand new cam chain feels about half a link too short. Got everything bolted up except the cam chain tensioner won't go on. A plate was made to space the tensioner back from the engine but I'm not overly happy about that and haven't attempted to start the bike since it's crank rebuild as a result.
I have had a new IWIS cam chain that was not able to be fitted to an SF. Side by side with a chain that did fit there was no difference in length but it was impossible to force onto the last tooth of the cam sprocket, a different brand sourced from Piet went straight on. The bike was standard, no skimming of head or barrel and new gaskets all torqued down.
As long as the adjuster wheel has a clean run the spacer shouldn't be a problem - better than running it all overtight, which will not be good for anything. How thick a spacer are you using? And a gasket on each side?
Pattern gaskets are too thick, pattern rubber tensioner block is too big, guide wheels too large diameter & possibly the barrel liners have risen slightly🤔. I used Phil Todd nylon guide wheels & gaskets, original chain and Kieth Nairn supplied the tensioner damper block.
Damper block was pushing the tensioner half out when relaxed, so I pre compressed the whole assembly before tightening the lock nut/adjuster bolt. Basically it went together with no play in cam chain but the tensioner is yet to do anything, it’s right back as such.
Multiple error reducing the slack due to pattern parts I’m afraid.
Could explain the problems. I was surprised my adjuster rubber block was installed new and when removed after melting a piston it had alreadt split ... chucked that and fitted a cut down new replacement.
Was the cam chain tensioner completely removed at the point you couldn't do the chain up?
I don't suppose you know the eeeeeeeeeeeeeeexact chain length do you? I think mine is IWIS too. Fitted, but as yet never turned more than a few revolutions.
The guide wheels were remade out of Delrin, it was a while ago but the dimensions came from someone reputable and IIRC were the same as the unworn parts of the follower. I still have the old ones, tempted to refit. I can't remember if we changed the tensioner block too, I don't think so.
I hope the tensioner isn't pressing on things a darn side harder than its spring tension then.
If you fit tensioner after fitting the chain you’ll soon see, doubling gaskets on tensioner could be a trick until it’s all settled down. I don’t like the idea of 50 year old manky yellow guides wheels spinning round, slowly disintegrating - but there are loads out there churning away.
Don’t force anything especially the tensioner bolts and you should be ok- seems a right old faff when it should be straight forward.
