motoddrob
- S/W Australia
You really are making it hard for yourself by leaving the motor in the frame.
The 'half' teeth Teddy is seeing is where the machining of the sprockets was made from the side. The cutters come in from the side and cut the pattern into the centre piece journal that butts up against the inner race of the main bearing."I see a separate sprocket but its off to the side"
this is a two row chain and (obviously) the crank and camshaft has double toothed sprockets,
As long as the adjuster wheel has a clean run the spacer shouldn't be a problem - better than running it all overtight, which will not be good for anything. How thick a spacer are you using? And a gasket on each side?I've got this to come - my brand new cam chain feels about half a link too short. Got everything bolted up except the cam chain tensioner won't go on. A plate was made to space the tensioner back from the engine but I'm not overly happy about that and haven't attempted to start the bike since it's crank rebuild as a result.
Was the cam chain tensioner completely removed at the point you couldn't do the chain up?I have had a new IWIS cam chain that was not able to be fitted to an SF. Side by side with a chain that did fit there was no difference in length but it was impossible to force onto the last tooth of the cam sprocket, a different brand sourced from Piet went straight on. The bike was standard, no skimming of head or barrel and new gaskets all torqued down.
The guide wheels were remade out of Delrin, it was a while ago but the dimensions came from someone reputable and IIRC were the same as the unworn parts of the follower. I still have the old ones, tempted to refit. I can't remember if we changed the tensioner block too, I don't think so.Pattern gaskets are too thick, pattern rubber tensioner block is too big, guide wheels too large diameter & possibly the barrel liners have risen slightly. I used Phil Todd nylon guide wheels & gaskets, original chain and Kieth Nairn supplied the tensioner damper block.
Damper block was pushing the tensioner half out when relaxed, so I pre compressed the whole assembly before tightening the lock nut/adjuster bolt. Basically it went together with no play in cam chain but the tensioner is yet to do anything, it’s right back as such.
Multiple error reducing the slack due to pattern parts I’m afraid.
I hope the tensioner isn't pressing on things a darn side harder than its spring tension then.Pattern gaskets are too thick, pattern rubber tensioner block is too big, guide wheels too large diameter & possibly the barrel liners have risen slightly. I used Phil Todd nylon guide wheels & gaskets, original chain and Kieth Nairn supplied the tensioner damper block.
If you fit tensioner after fitting the chain you’ll soon see, doubling gaskets on tensioner could be a trick until it’s all settled down. I don’t like the idea of 50 year old manky yellow guides wheels spinning round, slowly disintegrating - but there are loads out there churning away.I hope the tensioner isn't pressing on things a darn side harder than its spring tension then.
