No yellow inserted nuts Piet, come on mate you can do better than that! (ps if you find a source of them I will buy 250)
"seems a right old faff when it should be straight forward." I couldnt agree with you more EB, I bought my SF1 brand new and had no end of trouble fitting a new cam chain when Slaters were in their heyday and supplied factory parts, the reality is this.... at the time I thought I must change the internal engine chains, all three of them due to the mileage, which was at that time 25,000K's. I now know that this advice was probably due to the deal that Moto Laverda had with their chain supplier, who knows, just a guess, but there was no way that cam or primary (or even starter) chain needed changing, I kept them and used them for decades later after re-fitting, my triple gets far more use than my 750 these days and the same applies, the triplex primary will last a lot longer than manufacturers spec changing period, My son david (who is an engineer in ordance and explosives with MOD) did a clinical wash and measure of a triplex chain with more than 50,000 kilometres on it and a brand new one (same make) straight out of the box, and the difference was miniscule, read whatever you like into that.
Sure Clem, of course I could...
I do have a personal stash of freshly plated ones, ear-marked for those 120% restorations that I might get around to performing one day.
Manufacturers/outside suppliers need to reckon with the stupidity and ignorance of future users, hence the rather short specified change intervals. With the gentle use and low mileages these bikes see these days, along with the old codgers at the bars, chains will definitely last much, much longer than originally specified.
Never found any mention of timing chain replacement in Laverda factory literature. Guess Massimo never expected them to be used for much more than the 70-80000km the chains are at least good for, before being dumped for the next shiny toy. Even the service booklet for the RGS ends at 48000km. There, the primary chain change is specified at 24000 and 48000, no mention of timing chain except inspection thereof, but the tensioner blade was to be replaced every 16000km, along with a top-end de-coke! I do remember reading in a later factory publication that pistons were to be replaced at 60000km, apparently the factory was aware of the top ring groove wear issue.
I advise my customers to observe the short change intervals (chains and oil) as well. They'll swear on their mothers' grave that they will stick to running-in procedures, to stay under rev limits, etc, bla, bla, but I know for certain that some individuals don't care a rats arse about good (any!) advice and will gleefully murder their engine and come sulking back.
I too have managed to break a triplex primary chain. 2nd. to last lap on the Sunday of the 2010 Bikers Classics... not much damage, thankfully. Turned out it was from a incorrectly supplied batch that OCT ordered, chainman Andy later confirmed it to be of inferior quality. To be fair, it did hold up to 2 years of road use as well as 2 track weekends. Been running Andys' IWIS primary in the 3C since then, all others run on DID products.
