I rode Loïc’s SFC at the Amicale Rally at Archigny in the (mid?) 90ies, to find out that it was a whole quicker than my own SFC. Quite an eye opener it was, I realised work was needed on mine!
Marnix
Marnix
1994 I think. The time I got lost at night on the SFC looking for the campsite and considering sleeping in a ditch by the bike.
I rode it in 92 at the Amicale rally near home.
It had a 6C cam in it and Loic told me rev it. I did.
After 51 years the SFC wires still looking good.
The gasket on the other hand will require some work to remove.
It's hard as
Can highly recommend a demo saw blade with the saw teeth ground down and then an edge ground onto the end of it for use as a scraper. I also have one made from a large mechanical hacksaw blade, which is twice as wide. Nothing compares to old Honda Four gaskets - at Hartleys I eventually bailed on one and had the cover sent away to have the gasket milled off!! Ended up a lot cheaper than two hours of my labour.
I use a couple of wood-working chisels as these can be held and guided better than most improvised tools. Care and patience is still needed, some gaskets are a right bastard to remove, grey, black or green... thin remaining slivers are removed with an oil stone.
300 km on the SF2 in glorious weather.
I met up with the guys an gals from Dunkirk at the V3 base, or what's left of it at Mimoyecques, between Calais and Boulogne, 140 km from home.
Then, 60 km of country roads to a restaurant in French Flanders for a 3 course meal. Ideal in a heat wave.
Could one of the Dutch speakers translate the plaque on the small chapel?
After lunch, 100 km of small roads to home.
It is old Dutch/vlaams and has to do with the fishing community, the best translation I could come up with is in French:
Refuge des pécheurs, priez pour nous.
En mémoire/souvenir de Monsieur ....
Et Madame....
sa deuxième épouse (literalement: ménagère/housewife)
