S clutch dismantled and going back together.
It was slipping when cold and dragging when hot.
I didn't find anything very obvious.
The spring posts are very loosely located by clips at the bottom. Two of the clips were out of their respective grooves making the posts more mobile than the others. Would that entail the pressure plate not lifting squarely? I doubt it.
The springs were at the lower length limit so new ones going in. About 1.5mm in it.
I need to decide which rods to use. I'd put the two on the left in last time around. 224.67 total length but it didn't cure the drag and there was no adjustment left on the cable. The two other rods total 223.77mm. I'll probably do a mix to maintain some adjustment on the cable.
Maybe the drag is due to the new plates? They might need bedding in?
