Jota wiring question - stray brown wire
LDC420
UK - Kent
I have a stray brown wire underneath the tool tray of my Jota. I have no idea where it should attach, nor if it's always been there like this.
See video and pics.
Any suggestion, please?
most of your wiring going to that connector block is missing so you must have an aftermarket ignition system
in one of the later photos it shows what appears to be a DMC ignition box
if so a standard wiring layout is not going to be of much use
The photo is a bit fuzzy but it looks like it used to be a lug, if so then look for a screw with a thin, slightly oddly shaped brass washer under it.
Alternatively, you could tape it up so it doesn’t touch anything and see what doesn’t work!
Wire to rear light is usually brown (m - marrone on wiring diagram).
I was having a look at this and from the pictures its not very clear and the video doesn't seem to have been uploaded.
On mine there is a brown wire coming off the main loom which goes to the positive terminal of the battery (on mine) however as Red has said you have a DMC ignition as do I but most of your wiring on the connector block seems to have vacated the area meaning it has been wired slightly differently.
Does everything work on the bike electrically?
My advice would be to look up the excellent wiring diagram that might be hiding in the library and compare/follow your bike to that.
As Andy says also look for a tab that could well have broken off at its fixing end.
Good luck........and check out the attached photo of mine. Brown wire is shown left lower.
Thanks all.
I realise now that I have no power to the ignition at all.
I do have a completely new ignition system, DMC, as suggested.
I can't find an obvious home for it.
Thanks all.
Do you have power elsewhere?
Brown or Marrone is one of the main feeds to the fuse box, from the battery, and one of the feeds to the ignition switch via a convoluted route. The other feed to the switch is red.
This sounds right. No power except across the battery terminals. I think it may just be from the positive terminal of the battery. When I was at the bike yesterday I hadn't tried to switch it on. Only this morning when I went back. (It's stored away from my place.)
Thanks.
You were spot on, along with Andy.
I knew the wire wasn't live, so when I touched it to the positive battery terminal I got power to the ignition, so I knew it was the main feed. (Ged from GCS said try the battery, too.)
When I undid the battery terminal I found the detached ring piece (oo err missus) and all was revealed (oo err missus).
Apologies for sounding like Frankie Howerd...
Thanks all.
Luigi
Thanks all.
Luigi
Good
One step in the right direction.
Can someone estimate the zap speed for a wrong connection of a black box? My reflexes are not exactly light speed these days.
