Have you not got the wiring diagram?I have a stray brown wire underneath the tool tray of my Jota. I have no idea where it should attach, nor if it's always been there like this.
See video and pics.
Any suggestion, please?
Thanks View attachment 99922View attachment 99923
Do you have power elsewhere?Thanks all.
I realise now that I have no power to the ignition at all.
I do have a completely new ignition system, DMC, as suggested.
I can't find an obvious home for it.
Ya sooooo funnySteve, next time you have the seat and tank off you might want to check the left hand frame weld. I could be wrong but i think there is a suggestion of dirt in there. Appologies if it's just a shadow . HTH.
This sounds right. No power except across the battery terminals. I think it may just be from the positive terminal of the battery. When I was at the bike yesterday I hadn't tried to switch it on. Only this morning when I went back. (It's stored away from my place.)Do you have power elsewhere?
Brown or Marrone is one of the main feeds to the fuse box, from the battery, and one of the feeds to the ignition switch via a convoluted route. The other feed to the switch is red.
You were spot on, along with Andy.Do you have power elsewhere?
GoodYou were spot on, along with Andy.
I knew the wire wasn't live, so when I touched it to the positive battery terminal I got power to the ignition, so I knew it was the main feed. (Ged from GCS said try the battery, too.)
When I undid the battery terminal I found the detached ring piece (oo err missus) and all was revealed (oo err missus).
Apologies for sounding like Frankie Howerd...
Thanks all.
Luigi
Educated guesswork.Blimey. Touching a mystery stray wire to the battery positive terminal to see what happens is a risky diagnostic procedure. You were lucky it worked out for you and you didn't let the smoke out of anything.
I'd already established that it wasn't live.Blimey. Touching a mystery stray wire to the battery positive terminal to see what happens is a risky diagnostic procedure. You were lucky it worked out for you and you didn't let the smoke out of anything.
