Its going on the dyno soon, so i may get the chance to try and optimise both setups.I'd give it a try without the stacks... or use shorter ones. Check out the shape of Reds racing intakes, way to go!
An hour or 2 with the carbs on a flow bench will most probably unleash a couple of ponies.
There's a lot i could have done but at least i came home with a running motor which is a priority.
Rob
