AJ
- 38°33'00.0"S 177°55'00"E
Hey Ian what changes can you see to know the rings have bedded in?
Absolutely......knowing the piston metallurgy and piston manufacturing process is exceptionally important, especially with hypereutectic pistons now in the mix. Piston taper is critically important along with skirt length. It's important for the owner/end user of the bike to understand what is required for engine longevity. As you've stated how the bike is warmed up plays a significant role.At the factory they would be put together dry , filled with oil, then the bike would be run on a rolling road through the gears - that’s before it’s crated & exported. I have still had bikes that have not run in after 500/ 1000 miles . Triumph had this on the 995 motors where they were burning oil through not having bedded in the rings through riding too gently, had it with GS1150 BMW engines as well. BMWs we used to put in a basic oil in instead of synthetic and they would sort them selves out- Triumphs advice was “ give it a good Birching ..”
Either way they have to run in under load, at running temp- too gentle and nothing beds in, too quickly and you can overheat the rings.
Most modern bikes run in under normal riding, so you just jump on them & go - just don’t redline it. Older air cooled stuff, Two strokes or anything with thick piston rings needs a more careful approach. Heat cycling is the norm for Chrome bore two strokes.
Running in on an auxiliary electric motor is pointless because nothing is at running temp. You must also be aware that a piston expands far quicker than the bore as it heats up- if you don’t warm the motor gently you can get piston “ cold “ seizure - forged pistons with big clearance will need warming up sympathetically. I built a Cosworth pistoned Fireblade that was noticeably mechanically louder than stock.
As I've stated to Mr. E Beast below this is mostly appicable to cast iron bores.Hey Ian what changes can you see to know the rings have bedded in?
