steph
- Torgny, Belgium
Question
Which online CAD software are you using ?
SketchUp ?
SketchUp ?
Good morning,
for improvement and expansion of the model:
- dimensions of the friction on the pad relative to piston center,
280 -> ID 201,5- inner diameter of the useable surface for 280 and 300 rotor, should be ca 200 and 220.
That's correct Roland.Steph, there are holes for M10 in the legs and M10x1.25 threads in the caliper, or different pitch?
1. Leg: is it possible to check these dimensions again: Y1 or Y1 + Y2, X1 for both lugs the same value? As accurate as possible please...
280 is real diameter, not chamfered2. Rotor 280: real diameter, chamfered with eg 0.5x45°? Same for 300mm. Nominal value is exact?
what about the difference between 35 an 38mm Ceriani?
I assume it is the same geometry for the parts in my model?
