Rocker Arm
- Burnham Buckinghamshire
I have just free'd off a stuck clutch on my 1000, prior to me purchasing the bike, it had been completely renovated and then left,
On re-assembly the Primary socket and and clutch housing sprockets are not aligned. The clutch housing is too far in towards the engine by 0.090".
There are no shim washers fitted to either shaft!
If I put such a large shim on the inside of the clutch housing, moving it outwards, I am worried the clutch housing will not engage with the first friction disc. Also I will not be able to fit a shim between the housing and the circlip!
The clutch housing fitted has the sprockets rivetted to it, presumably no rubber dampers fitted. This is an early bike, was this how the early ones were built?
My best option is to machine the face of the smaller primary sprocket to allow it to move in towards the engine and aligning the chain.
I have checked the clearance between the oil pump sprocket and chain there is a big enough gap to allow me to do that.
Any thoughts?
Any thoughts?
