Simonr501
- Lympne, Kent. UK
Paddy said:not mine![]()
Yours ain't quite standard, plus you have got the front calipers the wrong side of the fork legs
SimonR501 said:Yours ain't quite standard, plus you have got the front calipers the wrong side of the fork legs
blab said:Mine has reversed forks,cant see a spacer on the speedo side.Left disc looks a couple of mm closer to the slider than the right.Could this be causing my weave problem ?
Paddy said:According to Falloon there was only one casting for the legs as used on the Series 2 180 and they just reversed this on some 120's
blab said:That aint easy for me.
This is a fully restored bike,all that stuff is brand new.
Bent frame is looking ugly at this point.
sfcpiet said:Ex-factory, Laverda front axles were always inserted from the RH side, with the first step of the axle locating the speedo drive and clamping the wheel assembly to the LH slider. When the caliper position was changed, ie, the sliders swapped, the bore sizes were changed to suit, but the drain screws remained, now on the "wrong" side of the slider.
SimonR501 said:Hands up all Jota 120 owners that have the calipers in front of forks - not so fast Paddy!![]()
