chrisk
- Brisbane, Australia
Pfft, and I thought plane spotters were a tad eclepic.
But frame number stamp rubbing? That takes it to a whole new level.
By the way - If you have any complaints about my poor English, please contact Google's translation department - thank you.
Blimey. I bet the dark winter evenings just fly past !I am very familiar with what original Laverda frame and engine stamping s are like, including the factory modified ones (remember the series 11 Atlas bikes going to Austria? oh yes the factory did change VIN numbers before despatch) I have been looking at them for 45 years and as the UK link between government departments and the public, for classic Laverda registration purposes, I have close up photos and rubbings of approximately a zillion examples. Even though I can discard them after seven years I never have.
Well Yes, Yes I am. Cheers Jim from the Kootenays!I think he is referring to mods done at the factory before delivery.
I'm going to take a wild guess and say that you are the owner of this bike! Cheers from the Cariboo!
Jim
I guess first time for everything. This SF2 was original purchased by Slater's accountant after sitting in its packing crate for a few years.Never had one from this period without Laverda-logo on the instruments.
Never seen the month of production an type label.
Visual screws are original (SBE, 3F,...).
Exhaust-balancer missing.
Thomas aus LAU
Fuel Taps?You didn't mention the fuel taps.
Hi Wes 1,I guess first time for everything. This SF2 was original purchased by Slater's accountant after sitting in its packing crate for a few years.
Balance Box and pipes are sitting in my garage loft. Do owners still ride their Laverda with the Boxes?
Thanks for the nice comment, much appreciated.Gentlemen, let's play nicely!
I have two similarly stamped "Jan '74" headstock plates with the J stamp reversed - don't assume it's bogus.
Hey Thomas, I will take a look tomorrow. Thanks for the interest. Cheers.Hi Wes 1,
please could you go in your garage loft and ask one of the pipes sitting around, what happend with their clamps near the cylinder hat?
Normaly you have a gap of about 5 mm to the cylinder.
Let me guess - we have here „chopped“ clamps? ;-)
Thomas aus LAU
and at the risk of stating the obviousThanks for the nice comment, much appreciated.
The exhaust collector is indeed a big limitation if you like to get into it in the curves, it reduces your margin for error quite a bit. Many people are happy to have it though - but not me. It is also very efficient at making the bike very quiet without affecting performance.Balance Box and pipes are sitting in my garage loft. Do owners still ride their Laverda with the Boxes?Oh I guess if you avoid doing that leaning thing in a curvy road
Would have been square type originally.Fuel Taps?OMG What about the Fuel Taps??????????
Hey Thomas, I compared the Balance Box headers with the ones that are on now. I didn't feel like taking a non balance header off to measure the length of the flange that inserts into the exhust port but it appears to be a bit longer than the balance box header. If so that would account for the extra spacing between the cylinder and the header coupler.Hey Thomas, I will take a look tomorrow. Thanks for the interest. Cheers.
I have the balance box on the SF2 which was my ride to work bike nearly until I retired. It's very noisy without.Do owners still ride their Laverda with the Boxes?Oh I guess if you avoid doing that leaning thing in a curvy road
I find that really odd, Paul, cos I ran my SF1 for decades and several hundred thousand km with rigidly mounted Ducati Contis, including race seasons and thousands of km on rugged Australian outback unsealed roads, corrugated to buggery and loaded with bulldust) - and never once had to retighten my headers at the flange. It's the system you can see part of in my avatar.My short experience without it ended because the exhaust system not being supported, it grinds away at the copper exhaust gaskets leading to having to tighten the collars to the head every day, or every couple of hours.
Can't have much exhaust stud left protruding from the flange on which to fit the brass M8s. Would be a good idea to rectify it by making a perpendicular cut with a cutoff angle grinding disc in a jig, back to the right size.Hey Thomas, I compared the Balance Box headers with the ones that are on now. I didn't feel like taking a non balance header off to measure the length of the flange that inserts into the exhust port but it appears to be a bit longer than the balance box header. If so that would account for the extra spacing between the cylinder and the header coupler.
But of course, the rear mounts might no longer align?Can't have much exhaust stud left protruding from the flange on which to fit the brass M8s. Would be a good idea to rectify it by making a perpendicular cut with a cutoff angle grinding disc in a jig, back to the right size.
Unless you also take the same amount off the rear of the header pipe.But of course, the rear mounts might no longer align?
