3C - Crankcase oil line fitting thread size = M12 x 1.5mm?
NJS
UK
Hi,
For a Triple - 3C- I did a search and I think that the crankcase threads for the oil lines are M12 x 1.5mm? Correct??
I have fittings - AN6 adaptor to M12 x 1.5mm.
(I then plan to use 3/8" or 9.5mm oil line using AN fittings to the cooler I have)
I just wanted to double check engine / block thread size is correct?. (Laverda Paradies - I see says M12 - but not pitch)
Thanks!
Rusty Spokes said:
NJS. no one has jumped in to reply..so if needed I will remove and measure my 3c oil line fittings..Piet or others surly know off the top of their heads?
Dunno what thread you will find, but I've come across 3 different ones, apparently all factory standard... even including one imperial size!  ::)
M12x1.5 is one of them.
Good luck.
Hi,
Many thanks for replies, and this was to give me confidence I'm on the right lines (literally) before I insert adaptor. I did just check and received today some M12 x 1.5mm nuts - which screwed onto the original adaptors removed - which threaded down okay- so it matches without a cross thread worry into crankcase.
The adaptors I obtained were as per link below for info and seem fine.
Thanks again Gents for your help...
https://www.ebay.co.uk/itm/AN-6-AN6-JIC-Flare-to-M12x1-5-METRIC-STAINLESS-STEEL-STRAIGHT-MALE-Adapter-/302467661059
Brett said:
If its metric and 12mm then will be 1.5 as going into alloy
Dunno how reliable that rule is Brett. I was fiddling about with my Mitsubishi the other day and discovered a plumbing fitting (coolant pipe) that was M12 x 1.25.
Anyway, seems the OP is sorted, so all is good.
