3cl crankshaft sprocket nut tension?
ghwallice
Ipswich
Crankshaft sprocket nut tension.  Have done clutch and primary chain. I thought I had seen it somewhere, even thought I had a list of tension settings for the Breganzes, but can't find them. Thanks, Greg
Here ya go remember to clean and degrease the thread before using some loctite... ideally you should also a new tab washer.
http://www.laverdaforum.com/forum/index.php?topic=84506.0
And if you use a new tab washer, be VERY careful to support the end of the crank when you bend the tab over. Very easy to knock the end of the crank a little bit out of alignment and end up with the outer bearing spinning a hole through the outer case. Fixable if it happens but it's a crankshaft out job (= $$$$  ::))
Ken
