Is it just this 3CL or is this characteristic of this model.....
I have a 1976 3CL with Ignitech ignition, Nology coils, Dellorto PHFs.
Starting:
I use full choke and it starts immediately, then I take the choke off to get smoother running.
When the engine is up to running temperature ( after 3-4 min) the bike can't be faulted, runs great, idles all day at 800-1000 RPM. Like new.
Carb idle jets are set to about 1 1/2 turns out, and adjusted when the engine was up to temp. Carbs are balanced.
But.....until it warms up it will not idle and I have to hold the throttle at 1500 RPM to keep it going, otherwise it stalls.
Once up to temp, no problems.
Question: Is this cold-start-no-idle characteristic or typical of this model, or is there something I've got set incorrectly.
I would appreciate any suggestions or experience from other 3CL or Jota owners.
Starting:
